Problem with Flash drive while swapping failed disk
Hi all,
Something very strange seems to have happened to one of my unraid installs. I'll describe the set of circumstances as best I can and would really appreciate any advice as it's a real head-scratcher!
- One of my drives failed, red ball. Because I have limited bays in the case, I disabled the drive from the array, removed and installed a replacement drive
- Brought the array online, one disk missing so using parity to fill in
- Started a pre-clear on the new drive to make sure it's good
- unmenu stopped responding at some point during the pre-clear as did airvideo so I telnetted in to kill any errant processes and restart them
- I now notice that the /boot folder is completely empty, no kernel, no config directory, no unmenu directory
- The array is still up, the pre-clear finished fine
- There are lots of errors in the syslog like this: Media kernel: FAT: Directory bread(block 2591199) failed, which leads me to conclude the Flash drive has become unreadable.
So.. If I stop the array and reboot, and the config/super.dat file has been lost, presumably I will lose the data on the disabled drive?
If so, it seems like I should format the newly pre-cleared drive as a normal data disk and mirror all the files from the failed disk to this before I shut down? Then I can boot from a new usb key and at least have all of my files intact?
As I say, any advice appreciated. I won't do anything until I have a clear plan.
Many thanks in advance!
