September 22, 200719 yr Having a bit of a problem upgrading from 4.0 to 4.2-beta4. Using an Abit ab9 pro mainboard at it's latest bios rev. It seems that the two sata disks connected to the jmicron controller are not completely recognized by unraid even though they are recognized by the jmicron controller's bios. I say completely b/c the web interface shows one of the disks in it's proper place but is thought to be "changed" while the other is reported as missing. Since i have two keys i'm able to switch back and forth and the same setup works fine under 4.0. I've attached the syslog from an unsuccessful 4.2-beta4 boot. Any thoughts would be much appreciated.
September 24, 200719 yr Author Well for now I've just moved the two drives over to a two port promise controller. 4.2-beta4 sees the disks and I can start the array fine without enabling user shares. If I enable user shares and attempt to start the array, it stays in a perpetual "Starting" state.
October 9, 200719 yr Sorry, I was away and did not see this, but I have a few comments on your syslog. Your system seems to be laid out similar to mine, with 6 onboard SATA ports, an added JMB363 chipset providing 2 more, and a Silicon Image 3132 (mine on an addon card) providing 2 more. Device inventory: pci-0000:00:1f.2-scsi-5:0:0:0 (sdh) scsi-SATA_ST3500630AS_9QG0YGAR pci-0000:00:1f.2-scsi-4:0:0:0 (sdg) scsi-SATA_HDS725050KLA360_KRVN02ZAG3YH1C pci-0000:06:00.0-scsi-1:0:0:0 (sdi) scsi-SATA_Maxtor_7H500F0_H81BMY3H pci-0000:00:1f.2-scsi-2:0:0:0 (sde) scsi-SATA_HDS725050KLA360_KRVN02ZAG3WTWC pci-0000:00:1f.2-scsi-3:0:0:0 (sdf) scsi-SATA_Maxtor_7H500F0_H81BJYLH pci-0000:00:1f.2-scsi-1:0:0:0 (sdd) scsi-SATA_Maxtor_7H500F0_H81BW7EH pci-0000:00:1f.2-scsi-0:0:0:0 (sdc) scsi-SATA_Maxtor_7H500F0_H81C9ZTH pci-0000:04:00.0-scsi-0:0:0:0 (sda) scsi-SATA_ST3500630AS_9QG0YCPZ Oddly, the SI3132 ports are identified before the onboard SATA ports. The Seagate on the internal SI3132 port was assigned sda, then the 6 onboard ports were assigned, sdc through sdh. Then it attempted to identify and configure the JMB363 and things went wrong fast. Both ports produced a number of errors I've never seen before, then it did identify the second drive, a Maxtor as sdi, but with more and more errors, it dropped the speed down to PIO3. I doubt the drive would have been accessible without disk errors, but even if it was, it would be very slow. A Google search turned up reports of Linux compatibility issues, here's one: http://www.phoronix.com/scan.php?page=article&item=699&num=1. Another report concerning Mandriva Linux mentioned problems with the newer kernel version, although like yours it had worked on an older kernel release. You may have to wait for a newer BIOS release, -or- a newer kernel release to fix problems with Linux on the Abit AB9. From a couple of reports, and a message within your syslog, the irqpoll parameter added to the append line of the syslinux.cfg file *might* help. Disk7 was marked 'wrong' and Disk8 marked 'missing'. It would be interesting to see a syslog after a 4.0 boot for comparison. By the way, I suspect that the Seagate 500 with serial # ending in ...YGAR on sixth onboard SATA port, may still have the SATA150 jumper installed. It starts with a SATA link up 1.5 Gbps speed, while the other 5 onboard ports start with 3.0 Gbps. That Seagate ST3500630AS is a SATA300 drive.
October 12, 200719 yr Author First a big thanks to RobJ for the reply. Your analysis is very helpful. I'm currently running 4.0 using my onboard jmicron controller. I've attached the syslog from my most recent 4.0 boot for comparison. Although it shows errors as it starts, the disks are recognized in the SMU and I can place them in their appropriate slots and start the array with no issues. This weekend I will inspect that ST3500630AS for the SATA150 jumper. When troubleshooting this issue I updated the mainboard's bios to current rev. The update seemes to have updated the firmware for the jmicron chip, and the realtek lan adapter(s) as well. So despite not fixing the jmicron issue, I ended up with the fairly well known realtek driver problem. I've resolved that issue by disabling the onboard realtek adapters and installing an intel pro 1000 pci card. It seems that in the near term if i want to give 4.2 a try I'll have to go back to the promise sata controller. I don't mind it that much even though my parity syncs dropped from ~53 MB/sec to ~44 MB/sec with it. The thing that pushed me back to 4.0 was the fact that my array stayed in a perpetual starting state when I enabled user shares on 4.2beta4. Hopefully efforts with 4.2.1 this weekend will yield better results. syslog below...couldn't attach: Oct 12 14:17:14 server emhttp[1373]: unRAID System Management Utility version 4.0 Oct 12 14:17:14 server emhttp[1373]: Copyright © 2005-2007, Lime Technology, LLC Oct 12 14:17:14 server emhttp[1373]: Device inventory: Oct 12 14:17:14 server emhttp[1373]: pci-0000:06:00.0-scsi-1:0:0:0 (sdj) scsi-SATA_ST3500630AS_9QG0YFC3 Oct 12 14:17:14 server emhttp[1373]: pci-0000:00:1f.2-scsi-3:0:0:0 (sdf) scsi-SATA_Maxtor_7H500F0_H81BJYLH Oct 12 14:17:14 server emhttp[1373]: pci-0000:00:1f.2-scsi-5:0:0:0 (sdh) scsi-SATA_ST3500630AS_9QG0YGAR Oct 12 14:17:14 server emhttp[1373]: pci-0000:00:1f.2-scsi-2:0:0:0 (sde) scsi-SATA_HDS725050KLA360_KRVN02ZAG3WTWC Oct 12 14:17:14 server emhttp[1373]: pci-0000:00:1f.2-scsi-4:0:0:0 (sdg) scsi-SATA_HDS725050KLA360_KRVN02ZAG3YH1C Oct 12 14:17:14 server emhttp[1373]: pci-0000:00:1f.2-scsi-0:0:0:0 (sdc) scsi-SATA_Maxtor_7H500F0_H81C9ZTH Oct 12 14:17:14 server emhttp[1373]: pci-0000:00:1f.2-scsi-1:0:0:0 (sdd) scsi-SATA_Maxtor_7H500F0_H81BW7EH Oct 12 14:17:14 server emhttp[1373]: pci-0000:06:00.0-scsi-0:0:0:0 (sdi) scsi-SATA_Maxtor_7H500F0_H81BMY3H Oct 12 14:17:14 server emhttp[1373]: pci-0000:04:00.0-scsi-0:0:0:0 (sda) scsi-SATA_ST3500630AS_9QG0YCPZ Oct 12 14:17:14 server emhttp[1373]: assign_device stat /dev/disk/by-path/pci-0000:03:00.0-scsi-0:0:0:0: 2 Oct 12 14:17:14 server emhttp[1373]: assign_device stat /dev/disk/by-path/pci-0000:04:00.0-scsi-1:0:0:0: 2 Oct 12 14:17:14 server emhttp[1373]: shcmd (1): rmmod md-mod >>/var/log/go 2>&1 Oct 12 14:17:14 server emhttp[1373]: shcmd (2): modprobe md-mod super=/boot/config/super.dat slots=8,48,8,32,8,80,8,64,8,96,8,112,0,0,8,0,0,0,0,0,0,0,0,0,0,0,0,0 >>/var/log/go 2>&1 Oct 12 14:17:14 server kernel: [ 287.402916] md: unRAID driver 0.92.0 installed Oct 12 14:17:14 server kernel: [ 287.744403] md: xor using function: pIII_sse (6779.200 MB/sec) Oct 12 14:17:14 server kernel: [ 287.745210] md: reading superblock from /boot/config/super.dat Oct 12 14:17:14 server kernel: [ 287.746336] md: superblock events: 10 Oct 12 14:17:14 server kernel: [ 287.746555] md0: import [8,48] (sdd) Maxtor 7H500F0 H81BW7EH offset: 63 size: 488386552 Oct 12 14:17:14 server kernel: [ 287.746603] md1: import [8,32] (sdc) Maxtor 7H500F0 H81C9ZTH offset: 63 size: 488386552 Oct 12 14:17:14 server kernel: [ 287.746647] md2: import [8,80] (sdf) Maxtor 7H500F0 H81BJYLH offset: 63 size: 488386552 Oct 12 14:17:14 server kernel: [ 287.746690] md3: import [8,64] (sde) HDS725050KLA360 KRVN02ZAG3WTWC offset: 63 size: 488386552 Oct 12 14:17:14 server kernel: [ 287.746733] md4: import [8,96] (sdg) HDS725050KLA360 KRVN02ZAG3YH1C offset: 63 size: 488386552 Oct 12 14:17:14 server kernel: [ 287.746776] md5: import [8,112] (sdh) ST3500630AS 9QG0YGAR offset: 63 size: 488386552 Oct 12 14:17:14 server kernel: [ 287.746779] md6: import: no device Oct 12 14:17:14 server kernel: [ 287.746781] md6: missing Oct 12 14:17:14 server kernel: [ 287.746851] md7: import [8,0] (sda) ST3500630AS 9QG0YCPZ offset: 63 size: 488386552 Oct 12 14:17:14 server kernel: [ 287.746854] md7: wrong Oct 12 14:17:14 server kernel: [ 287.746855] md8: import: no device Oct 12 14:17:14 server kernel: [ 287.746857] md8: missing Oct 12 14:17:14 server kernel: [ 287.746858] md9: import: no device Oct 12 14:17:14 server kernel: [ 287.746859] md10: import: no device Oct 12 14:17:14 server kernel: [ 287.746861] md11: import: no device Oct 12 14:17:14 server kernel: [ 287.746862] md12: import: no device Oct 12 14:17:14 server kernel: [ 287.746863] md13: import: no device Oct 12 14:17:14 server kernel: [ 287.749543] md0: import [8,48] (sdd) Maxtor 7H500F0 H81BW7EH offset: 63 size: 488386552 Oct 12 14:17:14 server kernel: [ 287.749613] md1: import [8,32] (sdc) Maxtor 7H500F0 H81C9ZTH offset: 63 size: 488386552 Oct 12 14:17:14 server kernel: [ 287.749686] md2: import [8,80] (sdf) Maxtor 7H500F0 H81BJYLH offset: 63 size: 488386552 Oct 12 14:17:14 server kernel: [ 287.749728] md3: import [8,64] (sde) HDS725050KLA360 KRVN02ZAG3WTWC offset: 63 size: 488386552 Oct 12 14:17:14 server kernel: [ 287.749772] md4: import [8,96] (sdg) HDS725050KLA360 KRVN02ZAG3YH1C offset: 63 size: 488386552 Oct 12 14:17:14 server kernel: [ 287.749814] md5: import [8,112] (sdh) ST3500630AS 9QG0YGAR offset: 63 size: 488386552 Oct 12 14:17:14 server kernel: [ 287.749818] md6: import: no device Oct 12 14:17:14 server kernel: [ 287.749819] md6: missing Oct 12 14:17:14 server kernel: [ 287.749887] md7: import [8,0] (sda) ST3500630AS 9QG0YCPZ offset: 63 size: 488386552 Oct 12 14:17:14 server kernel: [ 287.749890] md7: wrong Oct 12 14:17:14 server kernel: [ 287.749892] md8: import: no device Oct 12 14:17:14 server kernel: [ 287.749893] md8: missing Oct 12 14:17:14 server kernel: [ 287.749894] md9: import: no device Oct 12 14:17:14 server kernel: [ 287.749896] md10: import: no device Oct 12 14:17:14 server kernel: [ 287.749897] md11: import: no device Oct 12 14:17:14 server kernel: [ 287.749898] md12: import: no device Oct 12 14:17:14 server kernel: [ 287.749900] md13: import: no device Oct 12 14:17:14 server emhttp[1373]: shcmd (3): killall -w smbd nmbd Oct 12 14:17:15 server emhttp[1373]: Scanning user shares... Oct 12 14:17:15 server emhttp[1373]: shcmd (4): rm -r /mnt/user/* 2>/dev/null Oct 12 14:17:16 server emhttp[1373]: shcmd (5): /usr/sbin/nmbd -D Oct 12 14:17:16 server emhttp[1373]: shcmd (6): /usr/sbin/smbd -D Oct 12 14:18:16 server kernel: [ 348.904788] md0: import [8,48] (sdd) Maxtor 7H500F0 H81BW7EH offset: 63 size: 488386552 Oct 12 14:18:16 server kernel: [ 348.904878] md1: import [8,32] (sdc) Maxtor 7H500F0 H81C9ZTH offset: 63 size: 488386552 Oct 12 14:18:16 server kernel: [ 348.904943] md2: import [8,80] (sdf) Maxtor 7H500F0 H81BJYLH offset: 63 size: 488386552 Oct 12 14:18:16 server kernel: [ 348.905000] md3: import [8,64] (sde) HDS725050KLA360 KRVN02ZAG3WTWC offset: 63 size: 488386552 Oct 12 14:18:16 server kernel: [ 348.905041] md4: import [8,96] (sdg) HDS725050KLA360 KRVN02ZAG3YH1C offset: 63 size: 488386552 Oct 12 14:18:16 server kernel: [ 348.905083] md5: import [8,112] (sdh) ST3500630AS 9QG0YGAR offset: 63 size: 488386552 Oct 12 14:18:16 server kernel: [ 348.905086] md6: import: no device Oct 12 14:18:16 server kernel: [ 348.905087] md6: missing Oct 12 14:18:16 server kernel: [ 348.905150] md7: import [8,0] (sda) ST3500630AS 9QG0YCPZ offset: 63 size: 488386552 Oct 12 14:18:16 server kernel: [ 348.905153] md7: wrong Oct 12 14:18:16 server kernel: [ 348.905154] md8: import: no device Oct 12 14:18:16 server kernel: [ 348.905155] md8: missing Oct 12 14:18:16 server kernel: [ 348.905157] md9: import: no device Oct 12 14:18:16 server kernel: [ 348.905158] md10: import: no device Oct 12 14:18:16 server kernel: [ 348.905159] md11: import: no device Oct 12 14:18:16 server kernel: [ 348.905161] md12: import: no device Oct 12 14:18:16 server kernel: [ 348.905162] md13: import: no device Oct 12 14:19:16 server kernel: [ 408.846670] md0: import [8,48] (sdd) Maxtor 7H500F0 H81BW7EH offset: 63 size: 488386552 Oct 12 14:19:16 server kernel: [ 408.846748] md1: import [8,32] (sdc) Maxtor 7H500F0 H81C9ZTH offset: 63 size: 488386552 Oct 12 14:19:16 server kernel: [ 408.846813] md2: import [8,80] (sdf) Maxtor 7H500F0 H81BJYLH offset: 63 size: 488386552 Oct 12 14:19:16 server kernel: [ 408.846880] md3: import [8,64] (sde) HDS725050KLA360 KRVN02ZAG3WTWC offset: 63 size: 488386552 Oct 12 14:19:16 server kernel: [ 408.846922] md4: import [8,96] (sdg) HDS725050KLA360 KRVN02ZAG3YH1C offset: 63 size: 488386552 Oct 12 14:19:16 server kernel: [ 408.846963] md5: import [8,112] (sdh) ST3500630AS 9QG0YGAR offset: 63 size: 488386552 Oct 12 14:19:16 server kernel: [ 408.846967] md6: import: no device Oct 12 14:19:16 server kernel: [ 408.846968] md6: missing Oct 12 14:19:16 server kernel: [ 408.847037] md7: import [8,0] (sda) ST3500630AS 9QG0YCPZ offset: 63 size: 488386552 Oct 12 14:19:16 server kernel: [ 408.847039] md7: wrong Oct 12 14:19:16 server kernel: [ 408.847041] md8: import: no device Oct 12 14:19:16 server kernel: [ 408.847042] md8: missing Oct 12 14:19:16 server kernel: [ 408.847043] md9: import: no device Oct 12 14:19:16 server kernel: [ 408.847045] md10: import: no device Oct 12 14:19:16 server kernel: [ 408.847046] md11: import: no device Oct 12 14:19:16 server kernel: [ 408.847047] md12: import: no device Oct 12 14:19:16 server kernel: [ 408.847049] md13: import: no device Oct 12 14:20:16 server kernel: [ 468.788567] md0: import [8,48] (sdd) Maxtor 7H500F0 H81BW7EH offset: 63 size: 488386552 Oct 12 14:20:16 server kernel: [ 468.788640] md1: import [8,32] (sdc) Maxtor 7H500F0 H81C9ZTH offset: 63 size: 488386552 Oct 12 14:20:16 server kernel: [ 468.788704] md2: import [8,80] (sdf) Maxtor 7H500F0 H81BJYLH offset: 63 size: 488386552 Oct 12 14:20:16 server kernel: [ 468.788775] md3: import [8,64] (sde) HDS725050KLA360 KRVN02ZAG3WTWC offset: 63 size: 488386552 Oct 12 14:20:16 server kernel: [ 468.788816] md4: import [8,96] (sdg) HDS725050KLA360 KRVN02ZAG3YH1C offset: 63 size: 488386552 Oct 12 14:20:16 server kernel: [ 468.788856] md5: import [8,112] (sdh) ST3500630AS 9QG0YGAR offset: 63 size: 488386552 Oct 12 14:20:16 server kernel: [ 468.788859] md6: import: no device Oct 12 14:20:16 server kernel: [ 468.788861] md6: missing Oct 12 14:20:16 server kernel: [ 468.788929] md7: import [8,0] (sda) ST3500630AS 9QG0YCPZ offset: 63 size: 488386552 Oct 12 14:20:16 server kernel: [ 468.788932] md7: wrong Oct 12 14:20:16 server kernel: [ 468.788933] md8: import: no device Oct 12 14:20:16 server kernel: [ 468.788935] md8: missing Oct 12 14:20:16 server kernel: [ 468.788936] md9: import: no device Oct 12 14:20:16 server kernel: [ 468.788937] md10: import: no device Oct 12 14:20:16 server kernel: [ 468.788939] md11: import: no device Oct 12 14:20:16 server kernel: [ 468.788940] md12: import: no device Oct 12 14:20:16 server kernel: [ 468.788942] md13: import: no device Oct 12 14:21:16 server kernel: [ 528.720490] md0: import [8,48] (sdd) Maxtor 7H500F0 H81BW7EH offset: 63 size: 488386552 Oct 12 14:21:16 server kernel: [ 528.720567] md1: import [8,32] (sdc) Maxtor 7H500F0 H81C9ZTH offset: 63 size: 488386552 Oct 12 14:21:16 server kernel: [ 528.720632] md2: import [8,80] (sdf) Maxtor 7H500F0 H81BJYLH offset: 63 size: 488386552 Oct 12 14:21:16 server kernel: [ 528.720699] md3: import [8,64] (sde) HDS725050KLA360 KRVN02ZAG3WTWC offset: 63 size: 488386552 Oct 12 14:21:16 server kernel: [ 528.720740] md4: import [8,96] (sdg) HDS725050KLA360 KRVN02ZAG3YH1C offset: 63 size: 488386552 Oct 12 14:21:16 server kernel: [ 528.720781] md5: import [8,112] (sdh) ST3500630AS 9QG0YGAR offset: 63 size: 488386552 Oct 12 14:21:16 server kernel: [ 528.720784] md6: import: no device Oct 12 14:21:16 server kernel: [ 528.720785] md6: missing Oct 12 14:21:16 server kernel: [ 528.720853] md7: import [8,0] (sda) ST3500630AS 9QG0YCPZ offset: 63 size: 488386552 Oct 12 14:21:16 server kernel: [ 528.720856] md7: wrong Oct 12 14:21:16 server kernel: [ 528.720858] md8: import: no device Oct 12 14:21:16 server kernel: [ 528.720859] md8: missing Oct 12 14:21:16 server kernel: [ 528.720860] md9: import: no device Oct 12 14:21:16 server kernel: [ 528.720862] md10: import: no device Oct 12 14:21:16 server kernel: [ 528.720863] md11: import: no device Oct 12 14:21:16 server kernel: [ 528.720864] md12: import: no device Oct 12 14:21:16 server kernel: [ 528.720866] md13: import: no device Oct 12 14:22:16 server kernel: [ 588.662382] md0: import [8,48] (sdd) Maxtor 7H500F0 H81BW7EH offset: 63 size: 488386552 Oct 12 14:22:16 server kernel: [ 588.662452] md1: import [8,32] (sdc) Maxtor 7H500F0 H81C9ZTH offset: 63 size: 488386552 Oct 12 14:22:16 server kernel: [ 588.662515] md2: import [8,80] (sdf) Maxtor 7H500F0 H81BJYLH offset: 63 size: 488386552 Oct 12 14:22:16 server kernel: [ 588.662577] md3: import [8,64] (sde) HDS725050KLA360 KRVN02ZAG3WTWC offset: 63 size: 488386552 Oct 12 14:22:16 server kernel: [ 588.662631] md4: import [8,96] (sdg) HDS725050KLA360 KRVN02ZAG3YH1C offset: 63 size: 488386552 Oct 12 14:22:16 server kernel: [ 588.662672] md5: import [8,112] (sdh) ST3500630AS 9QG0YGAR offset: 63 size: 488386552 Oct 12 14:22:16 server kernel: [ 588.662675] md6: import: no device Oct 12 14:22:16 server kernel: [ 588.662676] md6: missing Oct 12 14:22:16 server kernel: [ 588.662744] md7: import [8,0] (sda) ST3500630AS 9QG0YCPZ offset: 63 size: 488386552 Oct 12 14:22:16 server kernel: [ 588.662747] md7: wrong Oct 12 14:22:16 server kernel: [ 588.662748] md8: import: no device Oct 12 14:22:16 server kernel: [ 588.662750] md8: missing Oct 12 14:22:16 server kernel: [ 588.662751] md9: import: no device Oct 12 14:22:16 server kernel: [ 588.662752] md10: import: no device Oct 12 14:22:16 server kernel: [ 588.662754] md11: import: no device Oct 12 14:22:16 server kernel: [ 588.662755] md12: import: no device Oct 12 14:22:16 server kernel: [ 588.662756] md13: import: no device Oct 12 14:23:16 server kernel: [ 648.594304] md0: import [8,48] (sdd) Maxtor 7H500F0 H81BW7EH offset: 63 size: 488386552 Oct 12 14:23:16 server kernel: [ 648.594374] md1: import [8,32] (sdc) Maxtor 7H500F0 H81C9ZTH offset: 63 size: 488386552 Oct 12 14:23:16 server kernel: [ 648.594438] md2: import [8,80] (sdf) Maxtor 7H500F0 H81BJYLH offset: 63 size: 488386552 Oct 12 14:23:16 server kernel: [ 648.594508] md3: import [8,64] (sde) HDS725050KLA360 KRVN02ZAG3WTWC offset: 63 size: 488386552 Oct 12 14:23:16 server kernel: [ 648.594549] md4: import [8,96] (sdg) HDS725050KLA360 KRVN02ZAG3YH1C offset: 63 size: 488386552 Oct 12 14:23:16 server kernel: [ 648.594589] md5: import [8,112] (sdh) ST3500630AS 9QG0YGAR offset: 63 size: 488386552 Oct 12 14:23:16 server kernel: [ 648.594592] md6: import: no device Oct 12 14:23:16 server kernel: [ 648.594594] md6: missing Oct 12 14:23:16 server kernel: [ 648.594661] md7: import [8,0] (sda) ST3500630AS 9QG0YCPZ offset: 63 size: 488386552 Oct 12 14:23:16 server kernel: [ 648.594664] md7: wrong Oct 12 14:23:16 server kernel: [ 648.594665] md8: import: no device Oct 12 14:23:16 server kernel: [ 648.594667] md8: missing Oct 12 14:23:16 server kernel: [ 648.594668] md9: import: no device Oct 12 14:23:16 server kernel: [ 648.594669] md10: import: no device Oct 12 14:23:16 server kernel: [ 648.594671] md11: import: no device Oct 12 14:23:16 server kernel: [ 648.594672] md12: import: no device Oct 12 14:23:16 server kernel: [ 648.594674] md13: import: no device Oct 12 14:24:09 server kernel: [ 701.951504] md0: import [8,48] (sdd) Maxtor 7H500F0 H81BW7EH offset: 63 size: 488386552 Oct 12 14:24:09 server kernel: [ 701.951575] md1: import [8,32] (sdc) Maxtor 7H500F0 H81C9ZTH offset: 63 size: 488386552 Oct 12 14:24:09 server kernel: [ 701.951638] md2: import [8,80] (sdf) Maxtor 7H500F0 H81BJYLH offset: 63 size: 488386552 Oct 12 14:24:09 server kernel: [ 701.951700] md3: import [8,64] (sde) HDS725050KLA360 KRVN02ZAG3WTWC offset: 63 size: 488386552 Oct 12 14:24:09 server kernel: [ 701.951767] md4: import [8,96] (sdg) HDS725050KLA360 KRVN02ZAG3YH1C offset: 63 size: 488386552 Oct 12 14:24:09 server kernel: [ 701.951808] md5: import [8,112] (sdh) ST3500630AS 9QG0YGAR offset: 63 size: 488386552 Oct 12 14:24:09 server kernel: [ 701.951811] md6: import: no device Oct 12 14:24:09 server kernel: [ 701.951812] md6: missing Oct 12 14:24:09 server kernel: [ 701.951873] md7: import [8,0] (sda) ST3500630AS 9QG0YCPZ offset: 63 size: 488386552 Oct 12 14:24:09 server kernel: [ 701.951876] md7: wrong Oct 12 14:24:09 server kernel: [ 701.951877] md8: import: no device Oct 12 14:24:09 server kernel: [ 701.951879] md8: missing Oct 12 14:24:09 server kernel: [ 701.951880] md9: import: no device Oct 12 14:24:09 server kernel: [ 701.951881] md10: import: no device Oct 12 14:24:09 server kernel: [ 701.951883] md11: import: no device Oct 12 14:24:09 server kernel: [ 701.951884] md12: import: no device Oct 12 14:24:09 server kernel: [ 701.951885] md13: import: no device Oct 12 14:24:16 server kernel: [ 708.536207] md0: import [8,48] (sdd) Maxtor 7H500F0 H81BW7EH offset: 63 size: 488386552 Oct 12 14:24:16 server kernel: [ 708.536285] md1: import [8,32] (sdc) Maxtor 7H500F0 H81C9ZTH offset: 63 size: 488386552 Oct 12 14:24:16 server kernel: [ 708.536348] md2: import [8,80] (sdf) Maxtor 7H500F0 H81BJYLH offset: 63 size: 488386552 Oct 12 14:24:16 server kernel: [ 708.536417] md3: import [8,64] (sde) HDS725050KLA360 KRVN02ZAG3WTWC offset: 63 size: 488386552 Oct 12 14:24:16 server kernel: [ 708.536457] md4: import [8,96] (sdg) HDS725050KLA360 KRVN02ZAG3YH1C offset: 63 size: 488386552 Oct 12 14:24:16 server kernel: [ 708.536498] md5: import [8,112] (sdh) ST3500630AS 9QG0YGAR offset: 63 size: 488386552 Oct 12 14:24:16 server kernel: [ 708.536501] md6: import: no device Oct 12 14:24:16 server kernel: [ 708.536502] md6: missing Oct 12 14:24:16 server kernel: [ 708.536563] md7: import [8,0] (sda) ST3500630AS 9QG0YCPZ offset: 63 size: 488386552 Oct 12 14:24:16 server kernel: [ 708.536566] md7: wrong Oct 12 14:24:16 server kernel: [ 708.536567] md8: import: no device Oct 12 14:24:16 server kernel: [ 708.536569] md8: missing Oct 12 14:24:16 server kernel: [ 708.536570] md9: import: no device Oct 12 14:24:16 server kernel: [ 708.536571] md10: import: no device Oct 12 14:24:16 server kernel: [ 708.536573] md11: import: no device Oct 12 14:24:16 server kernel: [ 708.536574] md12: import: no device Oct 12 14:24:16 server kernel: [ 708.536576] md13: import: no device Oct 12 14:24:47 server in.telnetd[1421]: connect from 192.168.1.9 (192.168.1.9)
January 9, 200818 yr Is there any possibilty of this being fixed in a future release, 4.3 maybe? Currently using 4.0 on an abit ab9-pro and it works flawlessly, upgrading to 4.2.1 gave me these same issues. Thanks
January 18, 200818 yr Great, Thanks Tom. If when you have a fix if you would like me to try it then please let me know.
