Jump to content
  • 'Help Info' boxes expanded by default on Firefox - 6.10.0-rc4
    Tesla3327
    • Closed
    Hello,
    Unfortunately I upgraded from 6.9.2 to rc4 so I do not know if this is a new issue. AFAIK this has not yet been reported.
    On Firefox (v98.0.1 (64-bit)) the help info boxes are expanded by default. If they are closed, they will be open next time you return to the page.
    I tested on Chrome (V99.0.4844.82 (Official Build) (64-bit)), and Edge (V99.0.1150.46 (Official build) (64-bit)) and they are hidden by default as expected on both.
    Thanks for all the good work!
    tomservo-diagnostics-20220324-1408.zip
    User Feedback
    Recommended Comments
    Add a comment...
      Only 75 emoji are allowed.
  • Status Definitions
    Open = Under consideration.
    Solved = The issue has been resolved.
    Solved version = The issue has been resolved in the indicated release version.
    Closed = Feedback or opinion better posted on our forum for discussion. Also for reports we cannot reproduce or need more information. In this case just add a comment and we will review it again.
    Retest = Please retest in latest release.
    Priority Definitions
    Minor = Something not working correctly.
    Urgent = Server crash, data loss, or other showstopper.
    Annoyance = Doesn't affect functionality but should be fixed.
    Other = Announcement or other non-issue.
  • Create New...
