Jump to content
  • [6.12.2] Network adapter not appearing Network Settings
    kevin182
    • Minor
    UGREEN USB Network Adapter appears in System Devices but not in Network Settings to configure. I did see it show up in Network Settings in 6.11.5 but after upgrading it disappeared. Thank you.
    Amazon link
    Chip link
    UGREEN link
    How to reproduce:
    1. Plug in adapter in USB port
    2. Start Unraid server
    3. Adapter appears in System Devices but not Network Settings
    lucifer-diagnostics-20230704-2354.zip
    User Feedback
    Recommended Comments
    Same issue here, neither my onboard or usb network adapter shows up in the network settings. My USB adapter displays in system devices but not the onboard.
    Link to comment
    35 minutes ago, DanHolo said:
    neither my onboard
    This will be a different chip.
    Is this the same AX88179 NIC?
    Also please post diags.
    Link to comment
    Still not working in 6.12.3. 6.11.5 was working flawlessly.
    Update: AX88179 is still not working in 6.12.4
    Edited by Mainfrezzer
    Update
    Link to comment
    Add a comment...
      Only 75 emoji are allowed.
  • Status Definitions
    Open = Under consideration.
    Solved = The issue has been resolved.
    Solved version = The issue has been resolved in the indicated release version.
    Closed = Feedback or opinion better posted on our forum for discussion. Also for reports we cannot reproduce or need more information. In this case just add a comment and we will review it again.
    Retest = Please retest in latest release.
    Priority Definitions
    Minor = Something not working correctly.
    Urgent = Server crash, data loss, or other showstopper.
    Annoyance = Doesn't affect functionality but should be fixed.
    Other = Announcement or other non-issue.
  • Create New...
