Hi there,
it seems like there might be a bug with the wireguard integration in unraid. I read below that the routes for br0 access will automatically be created. Thus I should be able to connect from wireguard to unraid br0 docker container. And I am able to do that. Until I restart my machine.
After restarting my machine all docker containers including my nginx proxy manager are booting up again. But after the npm docker container started, it has the wrong routings towards wireguard. It's solved automatically though when restarting the container again.
Maybe some sort of race condition with docker and wireguard integration? Although I did set wait 60 on npm to test this and I still have the same result.
Output in container after unraid restart:
# traceroute 10.253.0.1 traceroute to 10.253.0.1 (10.253.0.1), 30 hops max, 60 byte packets 1 192.168.0.1 (192.168.0.1) 0.730 ms 0.745 ms 0.769 ms 2 192.168.2.1 (192.168.2.1) 1.256 ms 1.694 ms 1.703 ms 3 p3e9bf104.dip0.t-ipconnect.de (62.155.241.4) 21.984 ms !N 22.011 ms !N 22.006 ms !N # route Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface default 192.168.0.1 0.0.0.0 UG 0 0 0 eth0 192.168.0.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0 # ping 10.253.0.1 PING 10.253.0.1 (10.253.0.1): 56 data bytes 36 bytes from p3e9bf104.dip0.t-ipconnect.de (62.155.241.4): Destination Net Unreachable 36 bytes from p3e9bf104.dip0.t-ipconnect.de (62.155.241.4): Destination Net Unreachable 36 bytes from p3e9bf104.dip0.t-ipconnect.de (62.155.241.4): Destination Net Unreachable ^C--- 10.253.0.1 ping statistics --- 3 packets transmitted, 0 packets received, 100% packet loss
Output in container after NPM container restart:
1 10.253.0.1 (10.253.0.1) 0.117 ms 0.028 ms 0.043 ms
# route
10.253.0.0 192.168.0.231 255.255.255.0 UG 0 0 0 eth0
# ping 10.253.0.1
64 bytes from 10.253.0.1: icmp_seq=0 ttl=64 time=0.157 ms
64 bytes from 10.253.0.1: icmp_seq=1 ttl=64 time=0.133 ms
2 packets transmitted, 2 packets received, 0% packet loss
round-trip min/avg/max/stddev = 0.133/0.145/0.157/0.000 ms
Recommended Comments
There are no comments to display.
