Jump to content
  • Cache SSD not recognised when updating to 6.11.2
    ollyroo
    • Urgent
    After updating from what I think was 6.11.1 to 6.11.2 my Samsung_SSD_980_1TB is now not recognised as a pool device
    Attached is log
    Downgrading to 6.11.1 does not fix the problem
    ser-diagnostics-20221106-2040.zip
    User Feedback
    Recommended Comments
    Doesn't look like an Unraid problem:
    Nov  6 20:31:56 ser kernel: nvme nvme0: Device not ready; aborting reset, CSTS=0x1
    Nov  6 20:31:56 ser kernel: nvme nvme0: Removing after probe failure status: -19
    IIRC another user had a similar intermittent issue with the same or similar Samsung device, try power cycling the server and/or downgrading back to v6.11.0 to see it's still detected.
    Link to comment
    Add a comment...
      Only 75 emoji are allowed.
  • Status Definitions
    Open = Under consideration.
    Solved = The issue has been resolved.
    Solved version = The issue has been resolved in the indicated release version.
    Closed = Feedback or opinion better posted on our forum for discussion. Also for reports we cannot reproduce or need more information. In this case just add a comment and we will review it again.
    Retest = Please retest in latest release.
    Priority Definitions
    Minor = Something not working correctly.
    Urgent = Server crash, data loss, or other showstopper.
    Annoyance = Doesn't affect functionality but should be fixed.
    Other = Announcement or other non-issue.
  • Create New...
