Jump to content
  • Login Page stalls and does not go to dashboard on first attempt [6.8.2]
    kage1414
    • Annoyance
    I've been having this bug for a minute now since I updated to 6.8.2 (stable). I suppose it has something to do with the fix for the recent login page security issue.
    My first attempt at logging in to the Web GUI never works. I input my username and password and the page seems to stall. I refresh my browser and input my credentials a second time and immediately I'm taken to the unRaid dashboard. Has anybody else has had this issue?
    I've attached my diagnostics.
    tower-diagnostics-20200303-0948.zip
    User Feedback
    Recommended Comments
    To get the obvious out of the way, are you sure you're entering in the password correctly the first time.
    There was one attempt at logging in as root that failed and then you immediately successfully logged in the 2nd time.
    Another time, your first attempt was as "admin" (which would fail), and then the second attempt (as root) did succeed.
    Link to comment
    Yes, I'm entering it correctly.
    It seems I'm able to recreate this bug if I haven't used the GUI for a while. I just tried logging out and logging back in and the issue didn't appear. I will logout for a while and try to recreate the issue again and post the logs.
    Link to comment
    Add a comment...
      Only 75 emoji are allowed.
  • Status Definitions
    Open = Under consideration.
    Solved = The issue has been resolved.
    Solved version = The issue has been resolved in the indicated release version.
    Closed = Feedback or opinion better posted on our forum for discussion. Also for reports we cannot reproduce or need more information. In this case just add a comment and we will review it again.
    Retest = Please retest in latest release.
    Priority Definitions
    Minor = Something not working correctly.
    Urgent = Server crash, data loss, or other showstopper.
    Annoyance = Doesn't affect functionality but should be fixed.
    Other = Announcement or other non-issue.
  • Create New...
