- Solved
- Minor
This is a frustrating problem I cannot quite pinpoint, but will try to explain.
I updated from 7.1.2 to 7.1.4 a few days ago. I started having issues with Cloudflare tunnel docker. The tunnel kept degrading, then coming back, then degrading, then coming back, then degrading, then coming back, etc.
I initially thought it was a network cable issue, then an issue with one of my dockers using the tunnel, until I finally zeroed in (after a day) on cloudflare tunnel docker.
I then went about creating new tunnels, deleting old tunnels and adding and removing tokens, deleting the docker, installing a new docker –all to no avail.
After looking at forums, it dawned on me that this might be a networking issue with 7.1.4.
So I reverted back to 7.1.2.
But I am still having some wonky issues. For example, docker containers have are updates, but when I try, no updates download.
Plugins check for update and sometimes I get a broken link, sometimes not.
I am at my wits end. Any help would be appreciated. Thanks.tsunamidream-diagnostics-20250626-1935.zip
Quick note: my vms are rock solid. No networking issues with any of them.
