[SOLVED]: AFP permission problems using Finder
I think that it is better making a separate post than adding this to the 5.03 beta thread.
I am using AFP and have a share with two users assigned. One user with read/write and one user with only read permissions. I had to run the newperms script manually since it did not work from the gui. All files and folders now have user:group nobody:users and folder permissions are set to drwxr-xr-x and file permissions seem to be all over the place - some have -rw-rw---- others have -rw-rwS---.
From the Finder I am no longer able to change folder names or file names, nor can I delete folders or files. Has anyone else had this problem?
Samba works correctly: I can both change and delete files/folders.
I appreciate that.
Yes this is a bug fixed in -beta4.
That 'S' means the "setgid" bit is set.  The netatalk documentation says this should be set, but since, at present, unRAID only has one group (users), I think the S bit is effectively meaningless - but I have to investigate this further.  Still new to AFP :)
When you say no longer do you mean it worked at one time?
Sorry, I meant that it worked using 4.7. Since 4.7 didn't have afp support I would change that to it does not work in 5.03
Create/Delete/Rename of files and directories seemed to work for me.  Please install 5.0-beta4 and see if the issue persists.
I have a similar issue.  I'm running beta4 and one of my computers runs windows as is connected to the unRAID server using SMB (or just browsing through the network in Windows 7).  The Macs in my network however are now mounting the server using AFP.  What happens it seems is that sometimes the Windows computers can't access files that might have been altered by a Mac on the network.  There is something funky going on with permissions.  Maybe if there is a way to just set all permissions to 777 that would solve my problem
AFP is still very much a work-in-progress.  I need more information:
- disk share or user share?
- what security mode, public, secure or private?
- can use set up a reproducible test case?
AFP, as implemented by 'netatalk', is a bit quirky.  Add on top of that OS X in general is a bit quirky.  So there may be some quirks :)
+1 for saying netatalk's AFP implementation is a bit quirky
-1 for saying OS X in general is a bit quirky
Almost didn't make it out alive Tom.
LOL - you don't think .AppleDouble isn't a bit "quirky"?  How about creating a gazillion various other "hidden" files in every directory OS X ever traverses?  I'd say that's quirky :)
I still have the same problems with beta4 - can't change or delete folders or files on the user share with my user who has read/write permissions. Unfortunately nothing shows up in the system log. I can read the files (open them).
User share
AFP activated: Secure
two users allocated: one read/write and one read only.
SMB not active for share
Not sure what I should do since it seems to be working for some mac users.
My Mac: iMac 27, Snow Leopard 10.6.6
Strangely enough, everything works on a different share set up in the same fashion.
Well, I did give you +1 for netatalk being quirky. It isn't OSX that leaves all those files (except for .DS_Store files). The netatalk implementation does that. Granted, HFS+ is a whole different beast than most other filesystems.
Are these files/folders created by the user who has read/write permissions (guess it has to be right)?
And netatalk is set up to be fairly "chatty" so seeing a system log might shed some light.
User share
I only have 'Leopard' to test with.  Might be some kind of quirk feature relevant only to Snow Leopard.
It might be helpful to also see directory listings, if you don't mind revealing file names.  For example,
ls -l /mnt/user/<your problematic share>/*
Peace.
ls output from user share that does not allow changes using the Finder:
drwxrwx--- 1 nobody users 400 Sep 14  2008 The\ IT\ Crowd\ 1x/
drwxrwx--- 1 nobody users 424 Sep 14  2008 The\ IT\ Crowd\ 2x/
drwxrwx--- 1 nobody users 384 Jan  1  2009 The\ IT\ Crowd\ 3x/
drwxrwx--- 1 nobody users 296 Aug  9  2010 The\ IT\ Crowd\ 4x/
ls output from user share that does allow changes using the Finder:
drwxrws--- 1 nobody users  496 Oct  8  2005 Amorica/
drwxrws--- 1 nobody users  568 Sep 16  2009 Before\ the\ Frost/
drwxrws--- 1 nobody users  496 Mar 24  2005 By\ Your\ Side/
drwxrws--- 1 nobody users  320 Mar  7  2006 High\ Head\ Blues/
drwxrws--- 1 nobody users  800 Jun  6  2005 Live\ At\ The\ Beacon\ Theater\ 1996/
drwxrws--- 1 nobody users  192 Nov 18  2005 Live\ At\ The\ Mercy\ Lounge/
Only diff that I see is the s flag and I tested changing a folder to s on the user share that doesn't allow changes, but still no luck.
Are you saying that you can rename any of the folders in the first group, but none of folders from the second group?  Or are you talking about files within those folders?  If latter, lets see, e.g., output of:
ls -l America/*
Also would still like to see system log captured after generating finder errors.
What are the permissions of the share directory itself, i. e., the share root?
ls -l America/*
I can rename any from the second group, but none in the first group.
Output from ls -l Amorica/* (from the share that I can change / delete files and folders)
-rw-rwS--- 1 nobody users 38234576 Mar 24  2005 Amorica/01\ Gone.m4a
-rw-rwS--- 1 nobody users 34847798 Mar 24  2005 Amorica/02\ Conspiracy.m4a
-rw-rwS--- 1 nobody users 26994860 Mar 24  2005 Amorica/03\ High\ Head\ Blues.m4a
-rw-rwS--- 1 nobody users 39118504 Mar 24  2005 Amorica/04\ Cursed\ Diamond.m4a
-rw-rwS--- 1 nobody users 27742354 Mar 24  2005 Amorica/05\ Nonfiction.m4a
-rw-rwS--- 1 nobody users 39915864 Mar 24  2005 Amorica/06\ She\ Gave\ Good\ Sunflowers.m4a
-rw-rwS--- 1 nobody users 26453150 Mar 24  2005 Amorica/07\ P.25\ London.m4a
-rw-rwS--- 1 nobody users 37276270 Mar 24  2005 Amorica/08\ Ballad\ in\ Urgency.m4a
-rw-rwS--- 1 nobody users 37828392 Mar 24  2005 Amorica/09\ Wiser\ Time.m4a
-rw-rwS--- 1 nobody users 24430837 Mar 24  2005 Amorica/10\ Downtown\ Money\ Waster.m4a
-rw-rwS--- 1 nobody users 36785660 Mar 24  2005 Amorica/11\ Descending.m4a
Output from ls -l "The IT Crowd 1x"/* (from the share that I can not change / delete files and folders)
-rw-rw---- 1 nobody users 243793920 Jan  4  2007 The\ IT\ Crowd\ 1x/The\ IT\ Crowd\ 1x01\ -\ Yesterday's\ Jam.avi
-rw-rw---- 1 nobody users 244285440 Jan  4  2007 The\ IT\ Crowd\ 1x/The\ IT\ Crowd\ 1x02\ -\ Calamity\ Jen.avi
-rw-rw---- 1 nobody users 244498432 Jan  4  2007 The\ IT\ Crowd\ 1x/The\ IT\ Crowd\ 1x03\ -\ Fifty-Fifty.avi
-rw-rw---- 1 nobody users 243916800 Jan  4  2007 The\ IT\ Crowd\ 1x/The\ IT\ Crowd\ 1x04\ -\ The\ Red\ Door.avi
-rw-rw---- 1 nobody users 243781632 Jan  4  2007 The\ IT\ Crowd\ 1x/The\ IT\ Crowd\ 1x05\ -\ The\ Haunting\ of\ Bill\ Crouse.avi
-rw-rw---- 1 nobody users 243724288 Jan  4  2007 The\ IT\ Crowd\ 1x/The\ IT\ Crowd\ 1x06\ -\ Aunt\ Irma\ Visits.avi
Permissions on the share roots are:
drwxrwx---  1 nobody users for the share where I can make any changes from Finder
drwxrwx---  1 nobody users for the share where I can not make any changes from Finder
Some output from the syslog when I tried the my nas read/white user from a different os x user account
Feb 10 07:18:26 Nas afpd[1661]: server_child[1] 4814 done
Feb 10 07:18:26 Nas afpd[1661]: server_child[1] 4812 exited 1
Feb 10 07:18:28 Nas afpd[1661]: server_child[1] 4816 exited 1
Feb 10 07:18:28 Nas afpd[1661]: server_child[1] 4815 exited 1
Feb 10 07:18:28 Nas afpd[4817]: ASIP session:548(8) from 192.168.1.90:64638(5)
Feb 10 07:18:28 Nas afpd[1661]: server_child[1] 4817 done
Feb 10 07:23:41 Nas in.telnetd[4822]: connect from 192.168.1.90 (192.168.1.90)
Feb 10 07:23:45 Nas login[4823]: ROOT LOGIN on '/dev/pts/2' from '192.168.1.90'
Feb 10 07:28:14 Nas cnid_dbd[4769]: main: Idle timeout, exiting
Feb 10 07:28:16 Nas cnid_metad: cnid_dbd pid 4769 exited with exit code 0
Feb 10 07:36:24 Nas afpd[1661]: server_child[1] 4852 exited 1
Feb 10 07:36:24 Nas afpd[4853]: ASIP session:548(8) from 192.168.1.90:64848(5)
Feb 10 07:36:24 Nas afpd[1661]: server_child[1] 4853 done
Feb 10 07:36:24 Nas afpd[4854]: ASIP session:548(8) from 192.168.1.90:64849(5)
Feb 10 07:36:24 Nas afpd[4854]: login noauth
Feb 10 07:36:24 Nas afpd[4854]: login nobody (uid 99, gid 100) AFP3.1
Feb 10 07:36:25 Nas afpd[4858]: ASIP session:548(8) from 192.168.1.90:64852(5)
Feb 10 07:36:25 Nas afpd[1661]: server_child[1] 4857 exited 1
Feb 10 07:36:25 Nas afpd[1661]: server_child[1] 4858 done
Feb 10 07:36:25 Nas afpd[1661]: server_child[1] 4856 exited 1
Feb 10 07:36:39 Nas afpd[4859]: ASIP session:548(8) from 192.168.1.90:64858(5)
Feb 10 07:36:39 Nas afpd[4859]: DHX2 login: roland
Feb 10 07:36:39 Nas cnid_dbd[4860]: Setting uid/gid to 0/0
Feb 10 07:36:39 Nas cnid_dbd[4860]: Startup, DB dir /mnt/user/music/.AppleDB
Feb 10 07:36:40 Nas cnid_dbd[4861]: Setting uid/gid to 99/100
Feb 10 07:36:40 Nas cnid_dbd[4861]: Startup, DB dir /mnt/user/backup/.AppleDB
Feb 10 07:36:40 Nas afpd[4854]: logout nobody
Feb 10 07:36:40 Nas afpd[4854]: 0.36KB read, 0.34KB written
Feb 10 07:36:40 Nas afpd[1661]: server_child[1] 4854 done
Feb 10 07:36:41 Nas afpd[4859]: login roland (uid 1000, gid 100) AFP3.1
Feb 10 07:36:43 Nas afpd[4859]: getquota: special /mnt/user/video fails
Feb 10 07:36:43 Nas afpd[4859]: ipc_write: command: 2, pid: 4859, msglen: 24
Feb 10 07:36:43 Nas afpd[1661]: ipc_read: command: 2, pid: 4859, len: 24
Feb 10 07:36:43 Nas afpd[1661]: WARNING: 2 connections (2575, 4859), boottime identical, don't know if one needs to be disconnected.
Feb 10 07:36:43 Nas afpd[1661]: Setting clientid (len 16) for 4859, boottime 4D525A89
Feb 10 07:36:43 Nas afpd[1661]: ipc_get_session: len: 24, idlen 16, time 4d525a89
Feb 10 07:36:43 Nas afpd[4866]: ASIP session:548(8) from 192.168.1.90:64861(5)
Feb 10 07:36:43 Nas afpd[1661]: server_child[1] 4865 exited 1
Feb 10 07:36:43 Nas afpd[1661]: server_child[1] 4866 done
Feb 10 07:36:43 Nas afpd[1661]: server_child[1] 4864 exited 1
Feb 10 07:36:43 Nas afpd[4869]: ASIP session:548(8) from 192.168.1.90:64864(5)
Feb 10 07:36:43 Nas afpd[1661]: server_child[1] 4868 exited 1
Feb 10 07:36:43 Nas afpd[1661]: server_child[1] 4869 done
Feb 10 07:36:43 Nas afpd[1661]: server_child[1] 4867 exited 1
well I think I may have found the reason for not being able to change/delete files/folders from a particular user share. Since my original flash was only 128 MB and I was running out of room on it, I started using the method described in post  http://lime-technology.com/forum/index.php?topic=3846.msg34151#msg34151
When I upgraded to 5.03 I had problems getting afp to work so I took away a number of files that were left on my original flash in the config folder, but I guess that I didn't take away enough of them since I still had permission problems that no one else seemed to have. Well, now it works. The only files left in the config folder are:
*Pro.key
*go
*network.cfg
*oldPlus.key
*super.dat
*super.old
*timezone
Sorry for any extra work anybody did trying to help with this. I can see how workarounds like this or the unmenu can affect the implementation of new versions in a negative way.
Roland
  • 2 months later...
What was in your config folder before having those listed remaining?
I was able to write via AFP, but now can only do so through Samba.  And on a side note, my write speeds went from 50-60MB/s down to 1-2MB/s--no idea!
What can I check to figure out why my AFP is no longer able to write to any of my 2 shares?
