January 31, 20215 yr Hi All, Sorry if this is in the wrong spot, please let me know if it is. Have been a very long time unraid user and finally took the plunge and added a P2000 after getting a wicked deal on a used one. Everything is working great but there is some fan noise. While playing with nvidia-smi I noticed that when idle the fan is at 66-67%. I was looking at different switches and noticed that if I ran nvidia-smi -l and let it cycle, by the 3rd refresh the fan is down to 48% and the noise is gone. Since the server sits next to my desk, I've gotten in the habit of opening a terminal window and just letting it run minimized. Works good but I'm thinking I'm really not fixing anything. Any ideas on: why the command slows the fan? or Any other way to permanently slow the fan? or Any way to fix the fan (as I don't want to return the board). Thanks for any suggestions. when idle Sun Jan 31 13:17:18 2021 +-----------------------------------------------------------------------------+ | NVIDIA-SMI 455.45.01 Driver Version: 455.45.01 CUDA Version: 11.1 | |-------------------------------+----------------------+----------------------+ | GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC | | Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. | | | | MIG M. | |===============================+======================+======================| | 0 Quadro P2000 Off | 00000000:01:00.0 Off | N/A | | 67% 36C P0 18W / 75W | 0MiB / 5059MiB | 0% Default | | | | N/A | +-------------------------------+----------------------+----------------------+ while running nvidia-smi -l Sun Jan 31 13:16:49 2021 +-----------------------------------------------------------------------------+ | NVIDIA-SMI 455.45.01 Driver Version: 455.45.01 CUDA Version: 11.1 | |-------------------------------+----------------------+----------------------+ | GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC | | Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. | | | | MIG M. | |===============================+======================+======================| | 0 Quadro P2000 Off | 00000000:01:00.0 Off | N/A | | 47% 35C P8 4W / 75W | 0MiB / 5059MiB | 0% Default | | | | N/A | +-------------------------------+----------------------+----------------------+
February 2, 20215 yr That's interesting. I got so tired of hearing the high pitch whine that I tossed a water block on it. I remember looking around forums for a way to slow it down, but never found anything. The P state looks like it changed. P0 is high performance, P8 would be some throttled down state.
February 2, 20215 yr Author Well my 'fix' seems to consistently work. Thanks for info around power state. I wonder what causes the power state to lower only when looping the nvidia-smi command (and return to p0 when it stops). I would prefer to have to silence it by depending on my desktop continuously asking it to provide status. The P2000 is going to get annoyed with the dumb requests. 🙂 Just stopped the loop and it went to P0. When I started it again it was P0 for 2 iterations, then P5, then P8 where it settles. Mostly curiosity, I then started up a 4k-->1080p transcode. Temperature rose to 45C, utilization 3%, went to P0 but fan topped out at 50% rather than an idle 67%. Still silent at 50%. If anyone has ideas....
February 20, 20215 yr Author Not sure if bumping is frowned on, but anyone have any ideas? Alternatively is there a way to automate running the nvidia-smi -l command from the unraid server? Whenever I shutdown the desktop it gets noisy again.
January 2, 20224 yr Author I did fix it but it has been a while. If my status thing above is working then maybe this will work for you. I loaded plugin user scripts. Created a new script with the following to set persistence on each reboot. Seems to have worked. #!/bin/bash nvidia-smi -pm 1 echo persistence set
January 3, 20224 yr Author @JO5u I guess you can try the nvidia-smi -pm 1 command to see if it works for you before setting up the script
