Crizzo Posted January 31, 2021 Share Posted January 31, 2021 Hi, Here's the backstory. A week or so ago i tried updating my pihole server to the newest version. The update failed half way through so i just did a clean install of pihole. My Unraid server worked great and i had no other networking issues until the fresh install of pihole on my raspberry pi. During this i also had to reset of router because i couldn't access the routers gui. I had to call my isp and have them re-provision my modem in order to get an internet connection again. Since then i have to set up my pihole exactly how it is was before and did the same with the router. However Unraid is now unreachable via gui and my shares aren't accessible through windows anymore, plex won't start. basically nothing. I've deleted the network.cfg file, tried the same one i had before and nothing will work. I am needing some serious help here. I cannot figure what has happened. I attached my diagnostics file which is pretty much jibberish to me ha. blackfyre-diagnostics-20210130-2027.zip Quote Link to comment
Crizzo Posted January 31, 2021 Author Share Posted January 31, 2021 Forgot to mention, if i bypass pihole the same problem persists. Quote Link to comment
Frank1940 Posted January 31, 2021 Share Posted January 31, 2021 Try typing the following in the Browser's URL box: //192.168.1.234 And see what you get. Quote Link to comment
Frank1940 Posted January 31, 2021 Share Posted January 31, 2021 Test two: Type the following in Windows Explorer Address box (might not be the right term): \\192.168.1.234 And see what you get. Quote Link to comment
Crizzo Posted January 31, 2021 Author Share Posted January 31, 2021 (edited) 6 minutes ago, Frank1940 said: Try typing the following in the Browser's URL box: //192.168.1.234 And see what you get. Times out, also here is my latest diagnostics file with the network.cfg deleted. it assigned 192.168.1.48, same issue except this time i couldnt ssh into it. blackfyre-diagnostics-20210131-1758.zip Edited February 1, 2021 by Crizzo Quote Link to comment
Frank1940 Posted February 1, 2021 Share Posted February 1, 2021 In my opinion, You got some problems in your local network configuration-- not in your Unraid server. You should not be getting two different IP addresses for your server by a simple server reboot. The DHCP process should remember what IP address it assigned to a specific MAC address for fair period of time (say, a couple of days in a home environment). Deleting the Unraid Network configuration file(s) is normally used (1) when the hardware setup has changed or (2) the user has manually modified the network configuration into an unusable state. When the file(s) are deleted, Unraid will then set them in accordance with a set of rules that works 99.99% of the time. Quote Link to comment
Crizzo Posted February 2, 2021 Author Share Posted February 2, 2021 14 hours ago, Frank1940 said: In my opinion, You got some problems in your local network configuration-- not in your Unraid server. You should not be getting two different IP addresses for your server by a simple server reboot. The DHCP process should remember what IP address it assigned to a specific MAC address for fair period of time (say, a couple of days in a home environment). Deleting the Unraid Network configuration file(s) is normally used (1) when the hardware setup has changed or (2) the user has manually modified the network configuration into an unusable state. When the file(s) are deleted, Unraid will then set them in accordance with a set of rules that works 99.99% of the time. I agree with the networking issues. Ive reset the modem and router again tonight and still will not work. now it br0 is broadcasting 0.0.0.0 after i set a static ip. Quote Link to comment
