February 8, 20215 yr Community Expert 25 minutes ago, jayhay548 said: I added one to the pool - that didn't work. That was expected.
February 8, 20215 yr Author Ok that was expected. But what about the bit where I have removed it entirely and replaced it and still not working? James
February 8, 20215 yr Author Here it is: Fix common problems is saying array health pass! tower-diagnostics-20210208-1704.zip
February 8, 20215 yr Community Expert Those appear to be the same you posted before, old cache is still connected causing a lot of ATA errors, remove old cache and post new diags.
February 8, 20215 yr Author Thanks for your help! It is with the new drive. Shall I remove ANY cache drives?
February 9, 20215 yr Community Expert 12 hours ago, JorgeB said: old cache is still connected causing a lot of ATA errors, remove old cache and post new diags.
February 12, 20215 yr Author Ok so: I got SpaceInvader to help me. And he was brilliant!! We(he): formatted again the new cache and changed it to xfs. Then we copied the old cache to the newly formatted drive and bingo - worked! It would probably have been fine Jorge if I'd have done exactly what you sad and removed the old one first before putting the new one in. But there we are. All done. Probably caused by a power cut corruption so I'm getting a UPS! thanks all.
