Having an issue with a drive going down less than 2 days after adding a new drive to the system. Also some other weirdness.
I wake up today and see that my second disk is down. I recently (<48 hrs ago) upgraded my rig with a new disk, and reconfigured my sata cabling and power cabling. I have had no issues with the disk up until now, no smart errors or warnings, and disk health is still very good (been used less than 2 years. Today it's down completely. I have the disk log as well for the disk as of the last time it was spun up. I'm not sure if it's intact from the original error state, as I did start and stop the array.
Additionally, I was having some issues previously with a couple of things that I can't explain and suspect have nothing to do with this problem, but are worth mentioning anyways. 1. I was downloading a very large (1.7TB) torrent on my windows machine over the network connection to my storage server, but I was having issues with either the name of a certain file containing an illegal character for windows filesystem namespace (?) or a file name being too long for the address bar.
Anyways, thanks for any help you can lend me. Diagnostics are attached.
tower-diagnostics-20210413-0059.zip
Apr 12 19:09:38 Tower kernel: md: disk2 read error, sector=1216325224
Apr 12 19:09:38 Tower kernel: md: disk3 read error, sector=1216327048
You're having issues with multiple disks in different controllers, so possibly a power/connection problem.
What would you recommend I do from here then?
Power issues can have several origins, mainly:
  • insufficient Power Supply
  • defective PSU
  • too many drives to a single PSU lead
  • poor quality power splitter
What is your Power Supply ?
How are the disks connected to the PSU ?
  • defective PSU
I have a disk with Spin_Retry_Count at 720,000, even though it has been working perfectly up until now, and has no issues accepting files currently.
  • defective PSU
Additionally, I have attached here the smart reports for both the new disk, and the disk that has been disabled but reports good on smart test.
Additionally I need to get the re-enable drive procedure, as I know my original disk (disabled) to be good and working, but the wiki page for re-enabling has been wiped.
https://wiki.unraid.net/index.php?title=Troubleshooting&action=edit&redlink=1
thanks
tower-smart-20210413-0408 (BAD SMART NEW DISK).zip tower-smart-20210413-0413 (DRIVE WORKING UNTIL NEW DISK ADDED).zip
Edited by Connor Zook
Stop array, unassign the disable disk, start array, check that the emulated disk is still mounting, stop array, re-assign the disk, start array to begin rebuilding.
