August 24, 20215 yr Some of my doctors will not run the web UI? Specifically omada-controller, zoneminder or Xeoma. I get a " This site can’t be reached 192.168.0.200 refused to connect." Even stranger after trying to connect a couple times the doctor will automatically turn itself off. I've tried everything but I don't understand why these Dockers don't work. Strange enough I have a separate machine I use for testing and it's having the same problems. I've tried to using different parts and still no luck. adl-server-diagnostics-20210823-2327.zip
August 24, 20215 yr Post your docker run command for one of the problem dockers, as explained here: https://forums.unraid.net/topic/57181-docker-faq/?do=findComment&comment=564345
