hedrinbc Posted February 6, 2022 Share Posted February 6, 2022 (edited) Wanted to document this for others, if your Unraid system has Docker enabled there are very simple ways to stress your CPU and system for checking temperatures, cooling and stability. Even without prime95, stress or stress-ng being easily available as an Unraid “app” if you can access your server via ssh you can easily stress test and max out your server. A Docker image is available specifically built to stress the system made possible by DigitalOcean. 1) Login via SSH - Access your Unraid server via ssh. You’ll login with your root credentials. 2) Docker Command - Enter this command at the prompt to do a quick first test: docker run --rm -it progrium/stress --cpu 2 --io 1 --vm 2 --vm-bytes 128M --timeout 10s On first run Docker will download the Docker image from DockerHub and the command tells it to run on 2 CPUs for only 10 seconds. 3) Tweak For You Needs - After you are successful with your first run. Press the up arrow and your last command should be shown. Go ahead and tweak the "cpu" and "timeout" values to what’s appropriate to your system and the test you are looking to run. I wouldn't max to your total threads on the first few runs get a feel for how it effects the system. 4) Watch CPU Usage and Temps - You should be able to see your CPU ramping up on the Unraid Dashboard tab in your web browser and if you install Dynamix System Temp in the Apps tab you should also see your temps. Hope this helps someone! -Ben Edited February 6, 2022 by hedrinbc 6 Quote Link to comment
dnLL Posted July 2, 2023 Share Posted July 2, 2023 This is lovely. Can work as a user script as well. Be sure to read the parameters carefully on the docker hub webpage if you want to be able to stress test with or without saturating your CPU/memory completely. Quote Link to comment
