April 29, 201115 yr Newbie here. Thanks for the Great forum and unRaid community , I was able to setup my unRaid server and is working great. Intial setup is small 2X2TB Drive and a 2TB parity drive. I plan to expand later once initial kinks are resolved.. Past few days I have been trying to setup rsync so that i can backup all my PC's( 1 PC and 2 Laptops) important files to unRaid server everyday. All my PC's are either win 64 machines or Vista. Installed Delta copy in all these machines. I read every topic on rsync in this forum(Tibbar-WeeboTech) but still rsync is not working in my setup. I have setup rsyncd.conf file and s20-init.rsyncd file as well as described. Here is the error that I am getting. I am complete noob to linux. so please help me. root@Tower:/mnt/disk1/backup# /usr/bin/rsync rsync://Tower/ rsync: connection unexpectedly closed (0 bytes received so far) [receiver] rsync error: error in rsync protocol data stream (code 12) at io.c(632) [receiver=3.0.4] I tried IP address as well still same error
April 29, 201115 yr That error tells us rsync doesn't have enough information to do what you want. You'd get the same thing using "rsync horned:toad". It can be used many ways, but is generally called with more than what you show in your example. e.g. rsync -optionsandsuchthatoftenlookugly source destination Could you maybe reference a thread you learned from that would provide context?
April 29, 201115 yr Author Cyrnel Thanks. Here is the post that I was referring to. http://lime-technology.com/forum/index.php?topic=2165.0 I did setup rsyncd.conf file and S20-init.rsyncd files as described. I also added a line to the go script. Still not working and I getting error as I mentioned in my previous post. Thanks for the help
April 29, 201115 yr Author Cyrnel Some more additional info. my thought process was to setup rsync in unraid box as a server and deltacopy as client running in various PC's. I will then schedule backup run using deltacopy. But right now I am trying to test rsync @ unRaid and make sure it is setup correctly at the server end. 1. my rsyncd.conf is setup in /boot/custom/etc and /etc as described in the forum topic uid = root gid = root use chroot = no max connections = 4 pid file = /var/run/rsyncd.pid timeout = 600 log file = /var/log/rsyncd.log [backup] path = /mnt/disk1/backup comment = /mnt muthu files read only = FALSE list = yes 2. my S20-init.rsyncd file stored in /boot/custom/etc/rc.d/ #!/bin/bash if ! grep ^rsync /etc/inetd.conf > /dev/null ; then cat <<-EOF >> /etc/inetd.conf rsync stream tcp nowait root /usr/sbin/tcpd /usr/bin/rsync --daemon EOF read PID < /var/run/inetd.pid kill -1 ${PID} fi cp /boot/custom/etc/rsyncd.conf /etc/rsyncd.conf 3. Go Script I added a line /boot/custom/etc/rc.d/s20-init.rsyncd Now I tried to check running rsync @ unRaid I am getting the above error. your direction is appreciated.
April 29, 201115 yr Author Here syslog Error msg Apr 28 17:19:43 Tower rsyncd[2924]: bind() failed: Address already in use (address-family 2) Apr 28 17:19:43 Tower rsyncd[2924]: socket(10,1,6) failed: Address family not supported by protocol Apr 28 17:19:43 Tower rsyncd[2924]: unable to bind any inbound sockets on port 873 Apr 28 17:19:43 Tower rsyncd[2924]: rsync error: error in socket IO (code 10) at socket.c(541) [receiver=3.0.4]
April 29, 201115 yr A quick look says init doesn't know about rsync yet. If you haven't rebooted then you need to run your S20-init.rsyncd yourself. Next time you reboot the go script will have done it for you. Edit: Note your example here mixes "s20-init.rsyncd" and "S20-init.rsyncd" somewhat. Remember n*x is case sensitive so be careful of that.
