Drive replaced and errors during rebuild.
I think we are checking the wrong disk now.  I answered yes, then did what it said:
Is this ok ? (y/n)[n]: y
The fs may still be unconsistent. Run reiserfsck --check.
root@Cooper:~# reiserfsck --check /dev/sda1
The HDD access light is on the wrong drive.
  • Replies 62
  • Views 12.6k
When I say no, it says "Super block was not written" and quits.
I guess you need to answer "y" then.
Have you been physically moving disks around since you posted the screen shot earlier in this thread?
If not, then your motherboard is initializing the disks in different orders depending on when they spin up and are ready.
From the "ls" command output, the /dev/sda disk is the one with the serial number that ends in XP9F.  That old screen shot showed it as disk10.
Until you figure out which disk is which, you'll be fighting to get things corrected.   The device name can change from one boot to the next, it is a "feature" of linux.  (nothing to do with unRAID, just on how they elected to speed the boot process by assigning device names as they initialize)
Sorry to give you the news, but if you've been running the reiserfsck command on /dev/sda1, it is not the disk with the original issue, and not on the copy we made.
Please make sure you are running the commands on the correct disk by verification by the size, model, and serial number.
Hmm... it seems you're right.  All I've done is physically remove the bad drive from the array and rebooted after the copy completed, but I now realize this changed the disk order.  Arg!
The disk the contents were copied to is now at sdu / sdu1.
This is what I've done on this disk thus far now:
root@Cooper:~# reiserfsck --check /dev/sdu1
reiserfsck 3.6.21 (2009 www.namesys.com)
** If you are using the latest reiserfsprogs and  it fails **
** please  email bug reports to [email protected], **
** providing  as  much  information  as  possible --  your **
** hardware,  kernel,  patches,  settings,  all reiserfsck **
** messages  (including version),  the reiserfsck logfile, **
** check  the  syslog file  for  any  related information. **
** If you would like advice on using this program, support **
** is available  for $25 at  www.namesys.com/support.html. **
Will read-only check consistency of the filesystem on /dev/sdu1
Will put log info to 'stdout'
Do you want to run this program?[N/Yes] (note need to type Yes if you do):Yes
reiserfsck --check started at Mon Jun  6 12:20:37 2011
Replaying journal: No transactions found
Zero bit found in on-disk bitmap after the last valid bit.
Checking internal tree..
Bad root block 0. (--rebuild-tree did not complete)
Aborted
root@Cooper:~# reiserfsck --rebuild-sb /dev/sdu1
Will check superblock and rebuild it if needed
Did you use resizer(y/n)[n]: n
rebuild-sb: wrong block count occured (366284624), fixed (488378624)
rebuild-sb: wrong bitmap number occured (11179), fixed (14905)
rebuild-sb: wrong tree height occured (65535), zeroed
Reiserfs super block in block 16 on 0x4141 of format 3.6 with standard journal
Count of blocks on the device: 488378624
Number of bitmaps: 14905
Blocksize: 4096
Free blocks (count of blocks - used [journal, bitmaps, data, reserved] blocks): 366284624
Root block: 0
Filesystem is NOT clean
Tree height: 0
Hash function used to sort names: not set
Objectid map size 0, max 972
Journal parameters:
        Device [0x0]
        Magic [0x0]
        Size 8193 blocks (including 1 for journal header) (first block 18)
        Max transaction length 1024 blocks
        Max batch size 900 blocks
        Max commit age 30
Blocks reserved by journal: 0
Fs state field: 0x3:
        FATAL corruptions exist.
         some corruptions exist.
sb_version: 2
inode generation number: 0
UUID: 1514f794-9bb4-4a44-af63-4c4085fe960c
LABEL:
Set flags in SB:
Mount count: 1
Maximum mount count: 30
Last fsck run: Wed Jun  1 16:35:29 2011
Check interval in days: 180
Blocksize: 4096
Root block: 0
Tree height: 0
Journal parameters:
        Device [0x0]
        Magic [0x0]
        Max commit age 30
sb_version: 2
LABEL:
Set flags in SB:
Mount count: 1
Super block seems to be correct
reiserfsck --check started at Mon Jun  6 12:23:28 2011
Aborted
Try it with --rebuild-tree and then --check again.
Alright, it's going.  Thanks again guys!
It corrected a bunch of stuff, then spat this out:
Could not find a hash in use. Using "r5"
Selected hash ("r5") does not match to the hash set in the super block (not set).
       "r5" hash is selected
Flushing..finished
       Read blocks (but not data blocks) 434693323
               Leaves among those 11
                       - leaves all contents of which could not be saved and deleted 11
               Objectids found 2
Pass 1 (will try to insert 0 leaves):
####### Pass 1 #######
Looking for allocable blocks .. finished
Flushing..finished
       0 leaves read
               0 inserted
####### Pass 2 #######
Flushing..finished
No reiserfs metadata found.  If you are sure that you had the reiserfs
on this partition,  then the start  of the partition  might be changed
or all data were wiped out. The start of the partition may get changed
by a partitioner  if you have used one.  Then you probably rebuilt the
superblock as there was no one.  Zero the block at 64K offset from the
start of the partition (a new super block you have just built) and try
to move the start of the partition a few cylinders aside  and check if
debugreiserfs /dev/xxx detects a reiserfs super block. If it does this
is likely to be the right super block version.
If this makes you nervous, try  www.namesys.com/support.html,  and for
$25 the author of fsck,  or a colleague  if he is out,  will  step you
through it all.
Aborted
I know for a fact the original (bad) drive was unaligned.  The new drive that it was copied is 4k aligned.  Would this matter?
no, it would not matter.  BUT, if the partition actually stars on sector 63 instead of 64, then you need to fix that before the reiserfsck can find the file system.
(Otherwise, it will be looking in the wrong place)
Are you sure the partition starts on sector 64?
Type
fdisk -lu /dev/sdX
to find out.
WARNING: GPT (GUID Partition Table) detected on '/dev/sdt'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sdt: 2000.4 GB, 2000398934016 bytes
1 heads, 63 sectors/track, 62016336 cylinders, total 3907029168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00000000
   Device Boot      Start         End      Blocks   Id  System
/dev/sdt1              64  3907029167  1953514552   83  Linux
Partition 1 does not end on cylinder boundary.
You can use the utility Tom included on the 5.0beta6 release to fix the partitioning to start on sector 63, or the shell script I wrote will do the same (I think it was named unraid_partition_disk.sh )
Awesome news.  Another one of my drives completely died (complete hardware failure / click of death) during all of this, so I lost another 500 GB.  I decided to cut my losses, pull the "new" dead drive, the dying drive, and the drive I copied the dying drive to.  Replaced all 3 with new drives and let unraid do its thing.  It appears to have done data rebuild, but all 3 new drives are empty so it didn't actually write anything to them.  It says the parity is valid, but I'm not entirely sure if that's true.
At any rate everything is green now, and I can browse my shares.  Not sure what is missing yet, though.  I will still try and see if I can recover what was lost on the dying 1.5 TB drive (which was copied to the new 2 TB drive) when I do a little research in that script you mentioned...
But in the meantime I'm getting permission denied when trying to write / delete on some of my shares.
God, this is such a mess...
I tried running the permission script under utils, but still being denied access to write / delete.
How can I use this if I have the drive attached via an external USB dock?  All my slots are now full with replacements.  Thanks!
Hate to do this, but... *bump*
Still not sure what to do...
