August 9, 20224 yr I can connect to the server via SSH(filezilla) and i have the monitor showing me the IPv4 Address, its set to what it is normally set to (192.168.1.151) but i cannot connect to the server by typing "tower/" in the url search bar. It just times out and says theres a connection error. I have tried restarting the server, my pc, and the router. Im not sure how to fix it.
August 9, 20224 yr Author Mark as Solution 7 minutes ago, trurl said: Have you tried to connect using the IP address instead of the server name? yes, same result
August 9, 20224 yr Author 1 minute ago, ChristianMingle said: Mark as Solution yes, same result i shut down and removed the usb, ran chkdsk on it, and then put it into a new usb 2.0 slot, and now upon boot it is assigning a 169 adress, which if i recall means that it couldnt get assigned an address. What should i do to fix this?
August 9, 20224 yr Author 9 minutes ago, ChristianMingle said: i shut down and removed the usb, ran chkdsk on it, and then put it into a new usb 2.0 slot, and now upon boot it is assigning a 169 adress, which if i recall means that it couldnt get assigned an address. What should i do to fix this? OK so apparently the other USB 2.0 is broken, it always gives me a 169 address... i moved it back to the other one and now have a 192 address but back to square 1 where i cannot connect via tower/ or 192.168.1.151
August 9, 20224 yr 1 hour ago, ChristianMingle said: the other USB 2.0 is broken, it always gives me a 169 address No obvious reason a USB port problem would cause the router to not respond to DHCP. attach diagnostics to your NEXT post in this thread
August 9, 20224 yr Author 1 hour ago, trurl said: No obvious reason a USB port problem would cause the router to not respond to DHCP. attach diagnostics to your NEXT post in this thread tower-diagnostics-20220809-1519.zip
August 9, 20224 yr Author 1 minute ago, ChristianMingle said: tower-diagnostics-20220809-1519.zip 90.44 kB · 0 downloads ?????? as soon as i logged into root and did the diagnostics i can now connect via 192.168.1.151 even though i tried it like 150 times over the past 2 hours. what is going on lol
