August 11, 20224 yr Hi, I had issue where everything on my SSD cache drive vanished. I ended it fixing it by running xfs_repair on the drive, but even though everything is back, including Docker image file which shows modification once things were back, I get no Dockers showing up, even after reboot. I am figuring the image file is still corrupted or something and that I have to rebuild, but want to inquire first, as if I had to reinstall every Docker, not sure if every bit of config is there or not. I have a lot. Thanks.
August 11, 20224 yr Possibly new docker.img was created and has no dockers now. And recreating docker.img is what we would recommend anyway. Not really a problem as long as appdata and the templates on flash drive are still there since the dockers can just be downloaded again. attach diagnostics to your NEXT post in this thread.
August 11, 20224 yr Author I am figuring at the very least I'll need to reconfigure the order in which the apps are listed/startup, possibly wait delays, and whether to autostart? Is there anything else? I'd like to know what I need to make a note of that wouldn't be restored. Edited August 11, 20224 yr by Iceman24
August 11, 20224 yr Solution docker.img only using a few MB, probably empty really. https://wiki.unraid.net/Manual/Docker_Management#Re-Create_the_Docker_image_file https://wiki.unraid.net/Manual/Docker_Management#Re-Installing_Docker_Applications
August 11, 20224 yr 4 minutes ago, Iceman24 said: order in which the apps are listed/startup, possibly wait delays, and whether to autostart? Not sure about that, but how would you make note of it if you don't have it now? Do you have screenshots or any other record of that?
August 11, 20224 yr Author Just now, trurl said: Not sure about that, but how would you make note of it if you don't have it now? Do you have screenshots or any other record of that? I meant in the future. I have some screenshots of some parts of it, but now I'll need to screenshot all of it. I have so many apps I can't remember it all.
August 11, 20224 yr Author 5 minutes ago, trurl said: docker.img only using a few MB, probably empty really. https://wiki.unraid.net/Manual/Docker_Management#Re-Create_the_Docker_image_file https://wiki.unraid.net/Manual/Docker_Management#Re-Installing_Docker_Applications I didn't recreate it since it seemed to have done that. I just started reinstall Dockers. Thanks for your help.
August 11, 20224 yr 2 minutes ago, Iceman24 said: I didn't recreate it If it didn't exist simply having docker enabled would have.
