September 14, 20223 yr Hi unraid community, My unraid had one 1 Gigbyte PCI NIC, I want upgrade to 2.5GIgbyte. so I add a 2.5G usb NIC to my unraid, want to make it as my unraid main NIC, but it only show in system device, not in network setting solution already tried: - disable docker and vm server reboot nas-diagnostics-20220915-0010.zip
September 14, 20223 yr Probably not picking up a driver for it. What happens if you upgrade to 6.11.0-rc5?
September 14, 20223 yr Community Expert No driver being loaded, Realtek 2.5GbE Linux support is iffy, you can try v6.11.0-rc5 to see if the newer kernel includes one.
September 15, 20223 yr Author Solution confimed It`s driver problem, i thought it shows on system devices , that means already have driver fix by manual install Realtek driver: Edited September 15, 20223 yr by metajs
