November 28, 20223 yr Nov 27 03:34:19 Tower nginx: 2022/11/27 03:34:19 [error] 11559#11559: *4553 recv() failed (104: Connection reset by peer) while reading upstream, client: 192.168.12.141, server: , request: "GET //wsproxy/5700/ HTTP/1.1", upstream: "http://127.0.0.1:5700/", host: "192.168.12.56" Nov 27 03:39:26 Tower nginx: 2022/11/27 03:39:26 [error] 11559#11559: *8135 recv() failed (104: Connection reset by peer) while reading upstream, client: 192.168.12.141, server: , request: "GET //wsproxy/5700/ HTTP/1.1", upstream: "http://127.0.0.1:5700/", host: "192.168.12.56" Nov 27 06:08:24 Tower kernel: Plex Media Scan[36737]: segfault at 0 ip 000014ba456374dd sp 00007ffefe255d00 error 4 in libavcodec.so.58[14ba45605000+292000] Nov 27 18:08:09 Tower kernel: traps: Plex Transcoder[1195] trap divide error ip:1521fb7d9139 sp:7fff24e564d0 error:0 in libavformat.so.58[1521fb76d000+302000] Nov 27 18:08:09 Tower kernel: traps: Plex Transcoder[1195] trap divide error ip:1521fb7d9139 sp:7fff24e564d0 error:0 in libavformat.so.58[1521fb76d000+302000] Nov 28 04:12:12 Tower kernel: Plex Media Scan[11717]: segfault at 0 ip 0000146478b294dd sp 00007ffc94f16650 error 4 in libavcodec.so.58[146478af7000+292000] Nov 28 04:12:12 Tower kernel: Code: 41 56 41 54 53 0f 57 c0 0f 11 46 20 0f 11 46 10 0f 11 06 48 c7 46 30 00 00 00 00 8b 6f 10 48 8b 17 89 e9 48 89 e8 48 c1 e8 03 <8b> 04 02 0f c8 80 e1 07 d3 e0 8d 4d 10 8b 57 18 c1 e8 f0 39 ca 0f tower-diagnostics-20221129-0140.zip
November 29, 20223 yr I'm used to see those Plex Media scan segfaults on various diags, so probably normal, other errors are also harmless.
November 30, 20223 yr Author On 11/29/2022 at 1:19 PM, JorgeB said: I'm used to see those Plex Media scan segfaults on various diags, so probably normal, other errors are also harmless. Thanks .. I'll ignore then Rebulding 2 disabled drives in the hopes that it won't occur again.
