December 6, 20223 yr Hello community, can you recommend me a low-range GPU with the following specs? Passthrough to Ubuntu VM for browsing Youtube / watching 1080p Movies Low idle power! I try to keep my system idle-power as low as possible, so it would be nice if the GPU doesn't add much to that most of the time when the VM is shut down. Help is very much appreciated! Edited December 6, 20223 yr by adrifromhh
December 6, 20223 yr Why isn't the integrated gpu on your cpu enough for that use? assuming you still have the i3-7350k cpu
December 6, 20223 yr Author I actually couldn't get it to run with Ubuntu and other Debian-derivatives... But I could try to go further into that once more.
December 7, 20223 yr Author On 12/6/2022 at 4:21 PM, ralop said: Why isn't the integrated gpu on your cpu enough for that use? assuming you still have the i3-7350k cpu Okay so I've bitten my teeth out, reading through tons of threads, trying to get my configuration to passthrough the IGPU with no luck. It seems to be a gamble if this works. I would still appreciate a recommendation for a suitable low-power GPU. Thanks!
December 11, 20223 yr im also in the same boat. but i wanted to keep my IPGU for plex due to intel quicksync. i have an Nvidia gtx 1050TI in idle with the VM that utalises this gpu it gives me a tax of 15 KWH on top of my normal system. i might look arround for another device with lower a lower idle tax im thinking of down/upgrading to a GTX 1630 to maybe lower this idle power consumption Edited December 11, 20223 yr by okkies added gtx 1630
December 11, 20223 yr If all you are using a non-integrated GPU is to display browser or movie player video, and perhaps transcode video, assigned to a VM, a Nvidia Quadro T400 (not the old Quadro 400) or its predecessor Quadro P400 are good choices. At full power, they only draw 35W, and don't even require a power cable as they get all they need from the PCIe slot.
December 12, 20223 yr 22 hours ago, ConnerVT said: If all you are using a non-integrated GPU is to display browser or movie player video, and perhaps transcode video, assigned to a VM, a Nvidia Quadro T400 (not the old Quadro 400) or its predecessor Quadro P400 are good choices. At full power, they only draw 35W, and don't even require a power cable as they get all they need from the PCIe slot. I second the P400 - mine works great.
March 28, 20233 yr Author On 12/11/2022 at 10:32 PM, ConnerVT said: If all you are using a non-integrated GPU is to display browser or movie player video, and perhaps transcode video, assigned to a VM, a Nvidia Quadro T400 (not the old Quadro 400) or its predecessor Quadro P400 are good choices. At full power, they only draw 35W, and don't even require a power cable as they get all they need from the PCIe slot. I now got myself a PNY NVIDIA P-400. It runs with a Linux VM out of the box, but it only offers me strange uncommon resolutions, even though newest NVIDIA drivers were installed already. Do you have a VBIOS ROM for that card? I couldn't find one.
March 28, 20233 yr I haven't had any issues with it, though I rarely use it as an output/display device. Mostly for transcoding, but have occasionally used it for the Unraid GUI. You may want to ask over in the Nvidia Driver Plugin support thread.
March 31, 20233 yr Author It's working great now, without ROM. The problem was only while connecting through DVI. Displayport works fine, with 2K resolution. Thanks for the recommendation!
March 19, 20251 yr Hello. Old post, but topic still relevant. I just checked that my desktop devours 82 [W] on idle. That was with 3 monitors ON. When one display is ON it takes 56 [W]; less but still too much for doing nothing really. Ryzen CPUs are quite efficient so i suspect that GTX 1660 drains most of it. I'm checking every new generation of GPUs but seems developers don't care about our electricity bills. Even 9000 series of Radeon are not better in that regard. What's the problem with implementing ECO modes or dedicated blocks like e-cores CPUs? Instead we have melting connectors and jet-engine fan noise. I'm not buying new GPU until they solve this issue even though i do love some gaming. Regards
