January 24, 20233 yr I apologize of this is in the wrong spot. I am getting MCE notification in Fix Common Problems. This is the section of the logs that shows the MCE errors. Can anyone help? Jan 22 04:39:13 Tower mcelog: failed to prefill DIMM database from DMI data Jan 22 04:39:13 Tower mcelog: Kernel does not support page offline interface Jan 22 04:39:13 Tower mcelog: Running trigger `unknown-error-trigger' (reporter: unknown) Jan 22 04:39:13 Tower mcelog: CPU 1 on socket 0 received unknown error Jan 22 04:39:13 Tower mcelog: Location: CPU 1 on socket 0 Thank you in adavance.
April 25, 20242 yr Author 7 hours ago, Gex2501 said: I'm seeing this now myself. @x31337x were you able to fix? Yes. I ended up replacing the ram and that solved the issue. One of the sticks was bad.
