Help setting up NVM for Docker and HDD for NAS
I have one HDD drive and one NVMe drive. I've gone through the manual and searched previous posts however I'm still a bit confused how to store docker images and containers data on an NVMe drive. From what I read the recommendation is not to add NVMe drive to array but to create a pool for the NVMe drive.
On creating Unraid I've created a array device with single 8TB HDD. I've then loaded a couple of experimental Docker instances. This has created appdata, domains, isos and system shares on the 8TB HDD.
I've now created a pool using single NVMe drive. However, when i click on any of the above shares, I thought I would see the pool drive in the "Included disks" but it only shows HDD.
I'm not looking to use the NVMe as a cache drive. I want to use it as a permanent drive for Docker et al. What is the right way to host Docker and related files on the NVMe?
Thanks
Solved by glennbrown
Stop the array.
Add a pool, add the NVMe drive to that pool.
Start the array
In the appdata share settings change the following:
"Use cache pool (for new files/directories):"  - Set this to Prefer
"Select Cache Pool:" - Set this to name of the pool you created.
Do the above for the "system" share too
You will want to stop Docker then execute mover, that should move all data to the pool.
36 minutes ago, glennbrown said:
the appdata share
You want more than just appdata. Do all the default shares you have in that wiki link
 I did call out system too ;)
He did not mention using VM's but yes if you do run VM's that one as well. I see little benefit to have iso's sitting on a pool device fulltime. I just have mine personally set Yes for iso's
I do it that way too. Your VM doesn't need the iso after install.
I've spent so much time typing about getting these shares off the array I just started referring to the wiki
Marvellous!  Many thanks both!
The Docker image files were not moving even though the Containers were stopped. I realised I had to disable the Docker and VM in the Settings first then tried Mover again. All transferred to the NVMe pool now.
