Help with running Smart Checks on more drives than 25
Hello,
Hope everyone are having a good day!
I have successfully been running quick smart checks on my drives using user scripts and this script:
#!/bin/bash
for i in {b..z}; do
    smartctl --test=short /dev/sd$i
done
But this only work with drives up to 25 (sdz)
And i have 26 drives installed at the moment, which put the identifier up to sdaa, and the script doesn´t work if i set it as:
#!/bin/bash
for i in {b..aa}; do
done
Any hints on that i am doing wrong?
Solved by apandey
try this instead
#!/bin/bash
for disk in $(lsblk -I8,65,66 -ndo name); do
    smartctl --test=short /dev/${disk}
done
it lists names of all devices using lsblk, where major device numbers as 8, 65 or 66 (sd*), then loops through them
1 hour ago, apandey said:
try this instead
#!/bin/bash
done
Thanks for the quick reply, that solved it, does exactly what i needed.
Thanks again and have a mighty fine day!
