heoquoay Posted March 26, 2023 Share Posted March 26, 2023 My transfer speed only 50mbps. Is there a way to improve and make it faster for upload and download between device at home? Quote Link to comment
itimpi Posted March 26, 2023 Share Posted March 26, 2023 8 hours ago, heoquoay said: My transfer speed only 50mbps. Is there a way to improve and make it faster for upload and download between device at home? Transfer speed to and from what? You are likely to get better informed feedback if you include your system's diagnostics zip file attached to your net post in this thread so we can see more about your setup. Quote Link to comment
heoquoay Posted March 31, 2023 Author Share Posted March 31, 2023 On 3/26/2023 at 6:23 AM, itimpi said: Transfer speed to and from what? You are likely to get better informed feedback if you include your system's diagnostics zip file attached to your net post in this thread so we can see more about your setup. Transfer from my computer to unraid server. diagnostics-20230331-1924.zip Quote Link to comment
itimpi Posted April 1, 2023 Share Posted April 1, 2023 That speed is not atypical for writing to the array with default settings and not going via a pool acting as a cache. You did not mention which share you were writing to on the server to see if this is the case. You can normally make writes go faster if using Turbo Write in such a case as described here in the online documentation accessible via the ‘Manual’ link at the bottom of the GUI or the DOCS link at the top of each forum page. You also have your ‘system’ share set to be on the array which can adversely affect performance of docker containers and VMs and they could affect overall transfer speed if active. To rectify this change the Use Cache setting for this share to Prefer; disable the docker and VM services; run mover manually from the Main tab; and when mover finishes re-enable the docker and/or VM services and (optionally) set the Use Cache setting to Only. The Cache’ pool does not have a value set for its Minimum Free Space. This should be set to be more than the largest file you expect to be cached so that Unraid knows when it should stop caching files and go direct to the array. You never want a pool to get completely full as this can lead to file system corruption. Quote Link to comment
