May 20, 20233 yr Forgive me for the noob question. I have tried to search on notifications for Pool Offline Drives (specifically RAIDZ2 zfs, running 6.12-rc5) with no success. The Pool is 5 drives in "zfs" at "raidz2" in "1 group of 5." The SATA power connectors on one of my drives came loose and the only way I could see it was offline was because there was an "*" for the temp. When drives in the "Array" go offline, there are a flurry of notifications emails that are sent. For the Pool, I didn't receive anything. Mind you it was probably only offline for an hour when I moved the server on the shelf, but regardless, hoping that someone might have a suggestion or thoughts. Thanks for any feedback.
May 21, 20233 yr There are no system notifications for pool errors, it's an old request of mine and hopefully it will be implemented soon, for now you can use this script, it will generate s system notification if a pool is not healthy.
