Wiseone001 Posted June 1, 2023 Share Posted June 1, 2023 I have been having this issue for a while now, system runs as needed but it reboots and parity starts. it will run ok, not fast not slow but completes with 100% and stays there not terminating the process. any ideas? Currently sitting 100% and took this diag. Please help me identify whats going on. unraid-diagnostics-20230601-0837.zip Quote Link to comment
itimpi Posted June 1, 2023 Share Posted June 1, 2023 The diagnostics show that your docker.img file is corrupt. Since FCP is also warning about not being able to writ to the 'cache' pool that may also be corrupt. At the very least the docker.img file will need to be deleted and then recreated followed by re-installing your docker containers with settings intact via Apps->Previous Apps. I also notice that you have not set a Minimum Free Space value for the 'cache' pool. You want this to be more than the size of the largest file you expect to cache as BTRFS file systems tend to have problems if they get too full. Quote Link to comment
