Lock ups and incredibly slow performance going from 6.11.5 -> 6.12
Hi all, just branching this off from the 6.12 release.
Since updating my system performance has gone insanely bad, to the point the web interface is not usable if I perform a simple task like erasing a drive... I've been talking about this loosely in the Unraid discord but seems no one is able to really concentrate on the one issue to help, and I get that, there's a lot of people asking questions that overlap, it is what it is.
So I updated from a working system, no pre-existing issues. I then noticed my server seemed dead on first boot, no screen output, no ping etc, but I had to go for lunch, when I came back it was up and working. Logged in and then went to set up my cache from btrfs to ZFS and this is when I noticed these huge pauses.  To cut a long story short, I have no VMs, no docker containers etc running. System is an 11400 Intel so not old nor underpowered for the task at hand! Attached CPU usage when just asking it to format a drive, being the first peak (set to 5M) and then after startng the array with also the TOP output from console. Diagnostics also attached.
I have also updated my BIOS since having the issue, diagnostics are from before this. I've also recreatd a fresh USB image and transferred over my config, same issue. I have tried safe mode with no GUI and plugins, issue remains. Downgrading to 6.11.5 immediately resolves the issue.
atlas-diagnostics-20230619-0928.zip
Solved by Triplerinse
 It may may ne the 11th gen intel cpu issue.  I built my new server 2 months ago because the 11th gen was a great buy.
Yep that fixed it, not using the iGPU for anything I wasn't expecting that to work, especially as the Discord seemed to agree! Nonetheless we are now working.
5 hours ago, JorgeB said:
Try the modprobe line.
Can you better explain what this line does and how it will effect server?  I use I gpu for plex.
It disables some power saving features, but it's needed for 11th gen CPUs and the moment, or it's usually unstable.
