July 24, 20233 yr Hello fellow Unraid enthusiasts, I'm currently facing a perplexing issue with my Docker PostgreSQL 14 setup and could really use some valuable insights from this knowledgeable community. As a relative newcomer to SQL, I'm struggling to resolve the problem, and I'm hoping someone here might be able to lend a hand. Here's the situation: Recently, I decided to tidy up my database and consolidate it for various Docker apps, aiming for better organization. However, since this reconfiguration, I'm encountering the following error whenever I try to connect with "psql -U max": psql: error: connection to server on socket "/var/run/postgresql/.s.PGSQL.5432" failed: FATAL: role "max" does not exist Despite my best efforts to fix the issue, following tutorials and guides, the error stubbornly remains. I even went to the extent of deleting the Docker image and starting from scratch, but to no avail. To provide some context, here's a brief overview of what I've done: Attempted to consolidate all my Docker databases into a single location for improved organization. Ended up with the "role 'max' does not exist" error whenever I try to connect using "psql -U max." To make it easier for you to help me, here are some additional details: My system is running Unraid with Docker version 14 for PostgreSQL. I followed the official documentation and various online resources, but the issue persists. Given my limited experience with SQL, I might be overlooking something obvious, and that's where I hope this wonderful community can lend a hand. Additionally, to aid in troubleshooting, I've attached a diagnostics zip file containing relevant information about my setup. If anyone has encountered a similar problem or has any insights on how to troubleshoot and fix this error, I would be immensely grateful for your guidance. Your expertise and advice could really make a difference in getting my setup back on track. Thank you all in advance for your support and understanding. Looking forward to your responses! NeZios-diagnostics-20230724-2059.zip
July 24, 20233 yr Author Here is my docker command execution : docker run -d --name='postgresql14' --net='blancnet' -e TZ="Europe/Paris" -e HOST_OS="Unraid" -e HOST_HOSTNAME="FamilyXXX" -e HOST_CONTAINERNAME="postgresql14" -e 'POSTGRES_PASSWORD'='XXXX' -e 'POSTGRES_USER'='max' -e 'POSTGRES_DB'='FamilyXXX' -l net.unraid.docker.managed=dockerman -l net.unraid.docker.icon='https://github.com/juusujanar/unraid-templates/raw/master/img/PostgreSQL-logo.png' -p '5432:5432/tcp' -v '/mnt/cache/appdata/postgresql14':'/var/lib/postgresql/data':'rw' 'postgres:14' 24dc6abb9dcb940eacfa00a8c78d76ba73529916d9dfa509b635ddb7c257f27d
February 22, 20242 yr Hi, were you able to solve the problem? I have the same issue. I need postgres for install immich. Grüße
