August 18, 20232 yr My device is the latest Intel chip N100 x86p5, with 16g of DDR5 memory and three 4t mechanical hard drives , no parity disk set, one 120g SSD ( Sata)for cache. disks read write should be no problem, both can reach 180-200m/sec, two network interfaces, ETH0 and ETH1, only ETH0 is conneted , all device supports Gigabit. eth0 network interface display 1000M (1000m/pbs, full duplex, mtu1500), static IP,shared by SMB, now the transmission speed from other LAN devices to Unraid device is too slow, only 10m. Help me tower-diagnostics-20230818-0801.zip.zip
August 18, 20232 yr Author Solution 51 minutes ago, JorgeB said: Are you transferring to cache or directly to the array? Problem solved when I replaced the operating device with wired network,The operating device (device 1) was wireless network initially, the Unraid server (device 2) and another LAN device for data transfering (device 3) were both wired networks.but i still feel strange. why this problem result of device 1's wireless network? Shouldn't it just be a device that issues operating instructions? is the data going through device 1?does that mean the speed will still be 10MB/s when i operate with my moblephone? Edited August 18, 20232 yr by dondong
August 18, 20232 yr Community Expert 1 hour ago, dondong said: Shouldn't it just be a device that issues operating instructions? If you were using device1 to transfer the data from 3 to 2 then the data would transverse the wireless network, and be slow.
August 18, 20232 yr Author 38 minutes ago, JorgeB said: If you were using device1 to transfer the data from 3 to 2 then the data would transverse the wireless network, and be slow. thank you for reply
