September 8, 201114 yr My Unraid box was working fine for months, then suddenly one day I got some blue lights next to some drives. Now when I rebuild parity around 80% the whole thing wonks out, I can't access anymore, and when I look at the syslog it looks like there's some sort of error but I can't tell what it is. Now when I try to login via Telnet the Telnet window just shuts down seconds after I try to type anything..no idea what I'm doing wrong or what happened. Please please help! I've attached the syslog - I can't tell if I have a bad drive, or a bad cable, or if I should turn off the box, or let it run.. or..I'm very scared of losing the data. syslog.txt
December 2, 201114 yr I'm experiencing the exact same thing. Every time my system goes to do a parity check, it loses all external connections -- no telnet, web, anything. I have to cross my fingers, hit the power switch, and hope nothing bad happens. Is there anyone that can help us diagnose what's happening?
December 2, 201114 yr Need a better idea of what hardware you have, and the entire syslog if possible. The snippet you posted shows problems that could be controller, cable or hard drive.
December 2, 201114 yr See here: http://lime-technology.com/wiki/index.php?title=The_Analysis_of_Drive_Issues
