Jump to content
Seeking Confirmation and Advice on Flash + Hard Drive Errors
Go to solution Solved by JorgeB,
Hello Unraid Community,
This morning, I encountered some errors that seem to relate to flash and hard drive failure. I’m seeking confirmation on my next steps and would appreciate input from those more knowledgeable in this area. I suspect the errors might be due to excessive write operations—possibly logging to USB—or a USB failure.
The usb and One drive is disabled (possibly unrelated?), and navigating around the UI results in:
Fatal Flash Drive Error
This usually means your flash drive is corrupted or has dropped offline. The rest of the Unraid GUI will also be affected. Post a new thread in the Unraid forums if this error continues
I would greatly appreciate any advice, comments, or suggestions that could assist me in better understanding this issue. If more details or clarifications are needed, please let me know, and I will provide them promptly.
Thank you in advance!
tower-diagnostics-20231002-0841.zip
Link to comment
  Only 75 emoji are allowed.
  • Create New...
