October 20, 20233 yr I logged into my unraid server 6.11.5 to find this message a couple days ago. I don't really know how to go about fixing this. I haven't tried any fixed yet because I didn't want to cause any more harm. I ran tools > diagnostics but I certainly can't decipher all that info. I'm posting some of syslog.1.txt here. Can someone give me some advice as to how I can solve this problem and not lose data? Thank you in advance. Oct 13 17:49:52 Tower vsftpd[23714]: connect from 192.168.0.118 (192.168.0.118) Oct 13 17:49:52 Tower vsftpd[23714]: [numa] OK LOGIN: Client "192.168.0.118" Oct 13 18:31:27 Tower vsftpd[741]: connect from 192.168.0.118 (192.168.0.118) Oct 13 18:31:27 Tower vsftpd[741]: [numa] OK LOGIN: Client "192.168.0.118" Oct 13 18:31:38 Tower vsftpd[801]: connect from 192.168.0.118 (192.168.0.118) Oct 13 18:31:38 Tower vsftpd[801]: [numa] OK LOGIN: Client "192.168.0.118" Oct 13 18:32:27 Tower vsftpd[803]: [numa] OK UPLOAD: Client "192.168.0.118", "/mnt/user/g..v", 568605951 bytes, 11514.79Kbyte/sec Oct 13 18:32:37 Tower vsftpd[803]: [numa] OK UPLOAD: Client "192.168.0.118", "/mnt/user/g..v", 120712864 bytes, 11580.13Kbyte/sec Oct 13 18:33:31 Tower vsftpd[803]: [numa] OK UPLOAD: Client "192.168.0.118", "/mnt/user/g..v", 613683629 bytes, 11162.12Kbyte/sec Oct 13 18:33:58 Tower vsftpd[803]: [numa] OK UPLOAD: Client "192.168.0.118", "/mnt/user/g..v", 319242327 bytes, 11542.00Kbyte/sec Oct 14 03:31:24 Tower crond[1219]: exit status 1 from user root /usr/local/sbin/mover &> /dev/null ### [PREVIOUS LINE REPEATED 1 TIMES] ### Oct 15 13:49:37 Tower kernel: usb 2-2: USB disconnect, device number 2 Oct 15 13:49:37 Tower kernel: usb 2-2: new SuperSpeed USB device number 3 using xhci_hcd Oct 15 13:49:37 Tower kernel: usb-storage 2-2:1.0: USB Mass Storage device detected Oct 15 13:49:37 Tower kernel: scsi host7: usb-storage 2-2:1.0 Oct 15 13:49:37 Tower emhttpd: Unregistered - flash device error (ENOFLASH3) Oct 15 13:49:37 Tower emhttpd: error: put_config_idx, 610: No such file or directory (2): fopen: /boot/config/shares/appdata.cfg Oct 15 13:49:37 Tower kernel: FAT-fs (sda1): Directory bread(block 29616) failed Oct 15 13:49:37 Tower kernel: FAT-fs (sda1): Directory bread(block 29617) failed Oct 15 13:49:37 Tower kernel: FAT-fs (sda1): Directory bread(block 29618) failed Oct 15 13:49:37 Tower kernel: FAT-fs (sda1): Directory bread(block 29619) failed Oct 15 13:49:37 Tower kernel: FAT-fs (sda1): Directory bread(block 29620) failed Oct 15 13:49:37 Tower kernel: FAT-fs (sda1): Directory bread(block 29621) failed Oct 15 13:49:37 Tower kernel: FAT-fs (sda1): Directory bread(block 29622) failed Oct 15 13:49:37 Tower kernel: FAT-fs (sda1): Directory bread(block 29623) failed Oct 15 13:49:37 Tower kernel: FAT-fs (sda1): Directory bread(block 29624) failed Oct 15 13:49:37 Tower kernel: FAT-fs (sda1): Directory bread(block 29625) failed Oct 15 13:49:37 Tower emhttpd: error: put_config_idx, 610: No such file or directory (2): fopen: /boot/config/shares/data.cfg Oct 15 13:49:37 Tower emhttpd: error: put_config_idx, 610: No such file or directory (2): fopen: /boot/config/shares/domains.cfg Oct 15 13:49:37 Tower emhttpd: error: put_config_idx, 610: No such file or directory (2): fopen: /boot/config/shares/go.cfg Oct 15 13:49:37 Tower emhttpd: error: put_config_idx, 610: No such file or directory (2): fopen: /boot/config/shares/isos.cfg Oct 15 13:49:37 Tower emhttpd: error: put_config_idx, 610: No such file or directory (2): fopen: /boot/config/shares/system.cfg Oct 15 13:49:37 Tower emhttpd: Starting services... Oct 15 13:49:37 Tower emhttpd: shcmd (121426): /etc/rc.d/rc.samba restart Oct 15 13:49:37 Tower wsdd2[3509]: 'Terminated' signal received. Oct 15 13:49:37 Tower winbindd[3512]: [2023/10/15 13:49:37.732200, 0] ../../source3/winbindd/winbindd_dual.c:1957(winbindd_sig_term_handler) Oct 15 13:49:37 Tower winbindd[3512]: Got sig[15] terminate (is_parent=1) Oct 15 13:49:37 Tower winbindd[3515]: [2023/10/15 13:49:37.732250, 0] ../../source3/winbindd/winbindd_dual.c:1957(winbindd_sig_term_handler) Oct 15 13:49:37 Tower winbindd[3515]: Got sig[15] terminate (is_parent=0) Oct 15 13:49:37 Tower wsdd2[3509]: terminating. Oct 15 13:49:37 Tower winbindd[4598]: [2023/10/15 13:49:37.733653, 0] ../../source3/winbindd/winbindd_dual.c:1957(winbindd_sig_term_handler) Oct 15 13:49:37 Tower winbindd[4598]: Got sig[15] terminate (is_parent=0) Oct 15 13:49:37 Tower root: cp: cannot create regular file '/boot/config': Input/output error Oct 15 13:49:38 Tower kernel: scsi 7:0:0:0: Direct-Access Kingston DataTraveler 3.0 PMAP PQ: 0 ANSI: 6 Oct 15 13:49:38 Tower kernel: sd 7:0:0:0: Attached scsi generic sg0 type 0 Oct 15 13:49:38 Tower kernel: sd 7:0:0:0: [sdf] 60604416 512-byte logical blocks: (31.0 GB/28.9 GiB) Oct 15 13:49:38 Tower kernel: sd 7:0:0:0: [sdf] Write Protect is off Oct 15 13:49:38 Tower kernel: sd 7:0:0:0: [sdf] Mode Sense: 45 00 00 00 Oct 15 13:49:38 Tower kernel: sd 7:0:0:0: [sdf] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA Oct 15 13:49:38 Tower kernel: sdf: sdf1 Oct 15 13:49:38 Tower kernel: sd 7:0:0:0: [sdf] Attached SCSI removable disk Oct 15 13:49:39 Tower usb_manager: Info: rc.usb_manager usb_remove Kingston_DataTraveler_3.0_E0D55EA57405E371B9C10019 /dev/bus/usb/002/002 002 002 Oct 15 13:49:39 Tower usb_manager: Info: rc.usb_manager usb_add Kingston_DataTraveler_3.0_E0D55EA57405E371B9C10019 /dev/bus/usb/002/003 002 003 Oct 15 13:49:39 Tower usb_manager: Info: rc.usb_manager Autoconnect No Mapping found Kingston_DataTraveler_3.0_E0D55EA57405E371B9C10019 /dev/bus/usb/002/003 002 003 port 2-2 Oct 15 13:49:39 Tower kernel: I/O error, dev loop1, sector 39200 op 0x0:(READ) flags 0x800 phys_seg 4 prio class 0 Oct 15 13:49:39 Tower kernel: SQUASHFS error: Failed to read block 0x1324c1c: -5 Oct 15 13:49:39 Tower kernel: I/O error, dev loop1, sector 39200 op 0x0:(READ) flags 0x800 phys_seg 4 prio class 0 Oct 15 13:49:39 Tower kernel: SQUASHFS error: Failed to read block 0x1324c1c: -5 Oct 15 13:49:39 Tower root: Starting Samba: /usr/sbin/smbd -D Oct 15 13:49:39 Tower smbd[8891]: [2023/10/15 13:49:39.763823, 0] ../../source3/smbd/server.c:1741(main) Oct 15 13:49:39 Tower smbd[8891]: smbd version 4.17.3 started. Oct 15 13:49:39 Tower smbd[8891]: Copyright Andrew Tridgell and the Samba Team 1992-2022 Oct 15 13:49:39 Tower root: /usr/sbin/nmbd -D Oct 15 13:49:39 Tower nmbd[8893]: [2023/10/15 13:49:39.783285, 0] ../../source3/nmbd/nmbd.c:901(main) Oct 15 13:49:39 Tower nmbd[8893]: nmbd version 4.17.3 started. Oct 15 13:49:39 Tower nmbd[8893]: Copyright Andrew Tridgell and the Samba Team 1992-2022 Oct 15 13:49:39 Tower root: /usr/sbin/winbindd -D Oct 15 13:49:39 Tower winbindd[8898]: [2023/10/15 13:49:39.804325, 0] ../../source3/winbindd/winbindd.c:1440(main) Oct 15 13:49:39 Tower winbindd[8898]: winbindd version 4.17.3 started. Oct 15 13:49:39 Tower winbindd[8898]: Copyright Andrew Tridgell and the Samba Team 1992-2022 Oct 15 13:49:39 Tower winbindd[8900]: [2023/10/15 13:49:39.809055, 0] ../../source3/winbindd/winbindd_cache.c:3116(initialize_winbindd_cache) Oct 15 13:49:39 Tower winbindd[8900]: initialize_winbindd_cache: clearing cache and re-creating with version number 2 Oct 15 13:49:39 Tower emhttpd: shcmd (121430): /etc/rc.d/rc.avahidaemon restart Oct 15 13:49:39 Tower root: Stopping Avahi mDNS/DNS-SD Daemon: stopped Oct 15 13:49:39 Tower avahi-daemon[3529]: Got SIGTERM, quitting. Oct 15 13:49:39 Tower avahi-dnsconfd[3538]: read(): EOF Oct 15 13:49:39 Tower avahi-daemon[3529]: Leaving mDNS multicast group on interface virbr0.IPv4 with address 192.168.122.1. Oct 15 13:49:39 Tower avahi-daemon[3529]: Leaving mDNS multicast group on interface docker0.IPv4 with address 172.17.0.1. Oct 15 13:49:39 Tower avahi-daemon[3529]: Leaving mDNS multicast group on interface br0.IPv4 with address 192.168.0.195. Oct 15 13:49:39 Tower avahi-daemon[3529]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1. Oct 15 13:49:39 Tower avahi-daemon[3529]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1. Oct 15 13:49:39 Tower avahi-daemon[3529]: avahi-daemon 0.8 exiting. Oct 15 13:49:39 Tower root: Starting Avahi mDNS/DNS-SD Daemon: /usr/sbin/avahi-daemon -D Oct 15 13:49:39 Tower avahi-daemon[8936]: Found user 'avahi' (UID 61) and group 'avahi' (GID 214). Oct 15 13:49:39 Tower avahi-daemon[8936]: Successfully dropped root privileges. Oct 15 13:49:39 Tower avahi-daemon[8936]: avahi-daemon 0.8 starting up. Oct 15 13:49:39 Tower avahi-daemon[8936]: Successfully called chroot(). Oct 15 13:49:39 Tower avahi-daemon[8936]: Successfully dropped remaining capabilities. Oct 15 13:49:39 Tower avahi-daemon[8936]: Loading service file /services/sftp-ssh.service. Oct 15 13:49:39 Tower avahi-daemon[8936]: Loading service file /services/smb.service. Oct 15 13:49:39 Tower avahi-daemon[8936]: Loading service file /services/ssh.service. Oct 15 13:49:39 Tower avahi-daemon[8936]: Joining mDNS multicast group on interface virbr0.IPv4 with address 192.168.122.1. Oct 15 13:49:39 Tower avahi-daemon[8936]: New relevant interface virbr0.IPv4 for mDNS. Oct 15 13:49:39 Tower avahi-daemon[8936]: Joining mDNS multicast group on interface docker0.IPv4 with address 172.17.0.1. Oct 15 13:49:39 Tower avahi-daemon[8936]: New relevant interface docker0.IPv4 for mDNS. Oct 15 13:49:39 Tower avahi-daemon[8936]: Joining mDNS multicast group on interface br0.IPv4 with address 192.168.0.195. Oct 15 13:49:39 Tower avahi-daemon[8936]: New relevant interface br0.IPv4 for mDNS. Oct 15 13:49:39 Tower avahi-daemon[8936]: Joining mDNS multicast group on interface lo.IPv6 with address ::1. Oct 15 13:49:39 Tower avahi-daemon[8936]: New relevant interface lo.IPv6 for mDNS. Oct 15 13:49:39 Tower avahi-daemon[8936]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1. Oct 15 13:49:39 Tower avahi-daemon[8936]: New relevant interface lo.IPv4 for mDNS. Oct 15 13:49:39 Tower avahi-daemon[8936]: Network interface enumeration completed. Oct 15 13:49:39 Tower avahi-daemon[8936]: Registering new address record for 192.168.122.1 on virbr0.IPv4. Oct 15 13:49:39 Tower avahi-daemon[8936]: Registering new address record for 172.17.0.1 on docker0.IPv4. Oct 15 13:49:39 Tower avahi-daemon[8936]: Registering new address record for 192.168.0.195 on br0.IPv4. Oct 15 13:49:39 Tower avahi-daemon[8936]: Registering new address record for ::1 on lo.*. Oct 15 13:49:39 Tower avahi-daemon[8936]: Registering new address record for 127.0.0.1 on lo.IPv4. Oct 15 13:49:39 Tower emhttpd: shcmd (121431): /etc/rc.d/rc.avahidnsconfd restart Oct 15 13:49:39 Tower root: Stopping Avahi mDNS/DNS-SD DNS Server Configuration Daemon: stopped Oct 15 13:49:39 Tower root: Starting Avahi mDNS/DNS-SD DNS Server Configuration Daemon: /usr/sbin/avahi-dnsconfd -D Oct 15 13:49:39 Tower avahi-dnsconfd[8948]: Successfully connected to Avahi daemon. Oct 15 13:49:40 Tower avahi-daemon[8936]: Server startup complete. Host name is Tower.local. Local service cookie is 3511801952. Oct 15 13:49:41 Tower emhttpd: error: put_config_idx, 610: No such file or directory (2): fopen: /boot/config/shares/appdata.cfg Oct 15 13:49:41 Tower emhttpd: error: put_config_idx, 610: No such file or directory (2): fopen: /boot/config/shares/data.cfg Oct 15 13:49:41 Tower emhttpd: error: put_config_idx, 610: No such file or directory (2): fopen: /boot/config/shares/domains.cfg Oct 15 13:49:41 Tower emhttpd: error: put_config_idx, 610: No such file or directory (2): fopen: /boot/config/shares/go.cfg Oct 15 13:49:41 Tower emhttpd: error: put_config_idx, 610: No such file or directory (2): fopen: /boot/config/shares/isos.cfg Oct 15 13:49:41 Tower emhttpd: error: put_config_idx, 610: No such file or directory (2): fopen: /boot/config/shares/system.cfg Oct 15 13:49:41 Tower emhttpd: Starting services... Oct 15 13:49:41 Tower emhttpd: shcmd (121437): /etc/rc.d/rc.samba restart Oct 15 13:49:41 Tower winbindd[8900]: [2023/10/15 13:49:41.096161, 0] ../../source3/winbindd/winbindd_dual.c:1957(winbindd_sig_term_handler) Oct 15 13:49:41 Tower winbindd[8900]: Got sig[15] terminate (is_parent=1) Oct 15 13:49:41 Tower nmbd[8897]: [2023/10/15 13:49:41.096161, 0] ../../source3/nmbd/nmbd.c:59(terminate) Oct 15 13:49:41 Tower nmbd[8897]: Got SIGTERM: going down... Oct 15 13:49:41 Tower winbindd[8909]: [2023/10/15 13:49:41.096201, 0] ../../source3/winbindd/winbindd_dual.c:1957(winbindd_sig_term_handler) Oct 15 13:49:41 Tower winbindd[8909]: Got sig[15] terminate (is_parent=0) Oct 15 13:49:41 Tower root: cp: cannot create regular file '/boot/config': Input/output error Oct 15 13:49:41 Tower avahi-daemon[8936]: Service "Tower" (/services/ssh.service) successfully established. Oct 15 13:49:41 Tower avahi-daemon[8936]: Service "Tower" (/services/smb.service) successfully established. Oct 15 13:49:41 Tower avahi-daemon[8936]: Service "Tower" (/services/sftp-ssh.service) successfully established. Oct 15 13:49:42 Tower kernel: I/O error, dev loop1, sector 39200 op 0x0:(READ) flags 0x800 phys_seg 4 prio class 0 Oct 15 13:49:42 Tower kernel: SQUASHFS error: Failed to read block 0x1324c1c: -5 Oct 15 13:49:42 Tower kernel: I/O error, dev loop1, sector 39200 op 0x0:(READ) flags 0x800 phys_seg 4 prio class 0 Oct 15 13:49:42 Tower kernel: SQUASHFS error: Failed to read block 0x1324c1c: -5 Oct 15 13:49:43 Tower root: Starting Samba: /usr/sbin/smbd -D Oct 15 13:49:43 Tower smbd[8988]: [2023/10/15 13:49:43.127559, 0] ../../source3/smbd/server.c:1741(main) Oct 15 13:49:43 Tower smbd[8988]: smbd version 4.17.3 started. Oct 15 13:49:43 Tower smbd[8988]: Copyright Andrew Tridgell and the Samba Team 1992-2022 Oct 15 13:49:43 Tower root: /usr/sbin/nmbd -D Oct 15 13:49:43 Tower nmbd[8990]: [2023/10/15 13:49:43.143554, 0] ../../source3/nmbd/nmbd.c:901(main) Oct 15 13:49:43 Tower nmbd[8990]: nmbd version 4.17.3 started. Oct 15 13:49:43 Tower nmbd[8990]: Copyright Andrew Tridgell and the Samba Team 1992-2022 Oct 15 13:49:43 Tower root: /usr/sbin/winbindd -D Oct 15 13:49:43 Tower winbindd[8995]: [2023/10/15 13:49:43.167627, 0] ../../source3/winbindd/winbindd.c:1440(main) Oct 15 13:49:43 Tower winbindd[8995]: winbindd version 4.17.3 started. Oct 15 13:49:43 Tower winbindd[8995]: Copyright Andrew Tridgell and the Samba Team 1992-2022 Oct 15 13:49:43 Tower winbindd[8997]: [2023/10/15 13:49:43.172405, 0] ../../source3/winbindd/winbindd_cache.c:3116(initialize_winbindd_cache) Oct 15 13:49:43 Tower winbindd[8997]: initialize_winbindd_cache: clearing cache and re-creating with version number 2 Oct 15 13:49:43 Tower emhttpd: shcmd (121441): /etc/rc.d/rc.avahidaemon restart Oct 15 13:49:43 Tower root: Stopping Avahi mDNS/DNS-SD Daemon: stopped Oct 15 13:49:43 Tower avahi-daemon[8936]: Got SIGTERM, quitting. Oct 15 13:49:43 Tower avahi-dnsconfd[8948]: read(): EOF Oct 15 13:49:43 Tower avahi-daemon[8936]: Leaving mDNS multicast group on interface virbr0.IPv4 with address 192.168.122.1. Oct 15 13:49:43 Tower avahi-daemon[8936]: Leaving mDNS multicast group on interface docker0.IPv4 with address 172.17.0.1. Oct 15 13:49:43 Tower avahi-daemon[8936]: Leaving mDNS multicast group on interface br0.IPv4 with address 192.168.0.195. Oct 15 13:49:43 Tower avahi-daemon[8936]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1. Oct 15 13:49:43 Tower avahi-daemon[8936]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1. Oct 15 13:49:43 Tower avahi-daemon[8936]: avahi-daemon 0.8 exiting. Oct 15 13:49:43 Tower root: Starting Avahi mDNS/DNS-SD Daemon: /usr/sbin/avahi-daemon -D Oct 15 13:49:43 Tower avahi-daemon[9014]: Found user 'avahi' (UID 61) and group 'avahi' (GID 214). Oct 15 13:49:43 Tower avahi-daemon[9014]: Successfully dropped root privileges. Oct 15 13:49:43 Tower avahi-daemon[9014]: avahi-daemon 0.8 starting up. Oct 15 13:49:43 Tower avahi-daemon[9014]: Successfully called chroot(). Oct 15 13:49:43 Tower avahi-daemon[9014]: Successfully dropped remaining capabilities. Oct 15 13:49:43 Tower avahi-daemon[9014]: Loading service file /services/sftp-ssh.service. Oct 15 13:49:43 Tower avahi-daemon[9014]: Loading service file /services/smb.service. Oct 15 13:49:43 Tower avahi-daemon[9014]: Loading service file /services/ssh.service. Oct 15 13:49:43 Tower avahi-daemon[9014]: Joining mDNS multicast group on interface virbr0.IPv4 with address 192.168.122.1. Oct 15 13:49:43 Tower avahi-daemon[9014]: New relevant interface virbr0.IPv4 for mDNS. Oct 15 13:49:43 Tower avahi-daemon[9014]: Joining mDNS multicast group on interface docker0.IPv4 with address 172.17.0.1. Oct 15 13:49:43 Tower avahi-daemon[9014]: New relevant interface docker0.IPv4 for mDNS. Oct 15 13:49:43 Tower avahi-daemon[9014]: Joining mDNS multicast group on interface br0.IPv4 with address 192.168.0.195. Oct 15 13:49:43 Tower avahi-daemon[9014]: New relevant interface br0.IPv4 for mDNS. Oct 15 13:49:43 Tower avahi-daemon[9014]: Joining mDNS multicast group on interface lo.IPv6 with address ::1. Oct 15 13:49:43 Tower avahi-daemon[9014]: New relevant interface lo.IPv6 for mDNS. Oct 15 13:49:43 Tower avahi-daemon[9014]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1. Oct 15 13:49:43 Tower avahi-daemon[9014]: New relevant interface lo.IPv4 for mDNS. Oct 15 13:49:43 Tower avahi-daemon[9014]: Network interface enumeration completed. Oct 15 13:49:43 Tower avahi-daemon[9014]: Registering new address record for 192.168.122.1 on virbr0.IPv4. Oct 15 13:49:43 Tower avahi-daemon[9014]: Registering new address record for 172.17.0.1 on docker0.IPv4. Oct 15 13:49:43 Tower avahi-daemon[9014]: Registering new address record for 192.168.0.195 on br0.IPv4. Oct 15 13:49:43 Tower avahi-daemon[9014]: Registering new address record for ::1 on lo.*. Oct 15 13:49:43 Tower avahi-daemon[9014]: Registering new address record for 127.0.0.1 on lo.IPv4. Oct 15 13:49:43 Tower emhttpd: shcmd (121442): /etc/rc.d/rc.avahidnsconfd restart Oct 15 13:49:43 Tower root: Stopping Avahi mDNS/DNS-SD DNS Server Configuration Daemon: stopped Oct 15 13:49:43 Tower root: Starting Avahi mDNS/DNS-SD DNS Server Configuration Daemon: /usr/sbin/avahi-dnsconfd -D Oct 15 13:49:43 Tower avahi-dnsconfd[9023]: Successfully connected to Avahi daemon. Oct 15 13:49:43 Tower kernel: fat__get_entry: 344 callbacks suppressed Oct 15 13:49:43 Tower kernel: FAT-fs (sda1): Directory bread(block 29616) failed Oct 15 13:49:43 Tower kernel: FAT-fs (sda1): Directory bread(block 29617) failed Oct 15 13:49:43 Tower kernel: FAT-fs (sda1): Directory bread(block 29618) failed Oct 15 13:49:43 Tower kernel: FAT-fs (sda1): Directory bread(block 29619) failed Oct 15 13:49:43 Tower kernel: FAT-fs (sda1): Directory bread(block 29620) failed Oct 15 13:49:43 Tower kernel: FAT-fs (sda1): Directory bread(block 29621) failed Oct 15 13:49:43 Tower kernel: FAT-fs (sda1): Directory bread(block 29622) failed Oct 15 13:49:43 Tower kernel: FAT-fs (sda1): Directory bread(block 29623) failed Oct 15 13:49:43 Tower kernel: FAT-fs (sda1): Directory bread(block 29624) failed Oct 15 13:49:43 Tower kernel: FAT-fs (sda1): Directory bread(block 29625) failed Oct 15 13:49:44 Tower avahi-daemon[9014]: Server startup complete. Host name is Tower.local. Local service cookie is 1596766609. Oct 15 13:49:44 Tower emhttpd: error: put_config_idx, 610: No such file or directory (2): fopen: /boot/config/shares/appdata.cfg Oct 15 13:49:44 Tower emhttpd: error: put_config_idx, 610: No such file or directory (2): fopen: /boot/config/shares/data.cfg Oct 15 13:49:44 Tower emhttpd: error: put_config_idx, 610: No such file or directory (2): fopen: /boot/config/shares/domains.cfg Oct 15 13:49:44 Tower emhttpd: error: put_config_idx, 610: No such file or directory (2): fopen: /boot/config/shares/go.cfg Oct 15 13:49:44 Tower emhttpd: error: put_config_idx, 610: No such file or directory (2): fopen: /boot/config/shares/isos.cfg Oct 15 13:49:44 Tower emhttpd: error: put_config_idx, 610: No such file or directory (2): fopen: /boot/config/shares/system.cfg Oct 15 13:49:44 Tower emhttpd: Starting services... Oct 15 13:49:44 Tower emhttpd: shcmd (121448): /etc/rc.d/rc.samba restart Oct 15 13:49:44 Tower nmbd[8994]: [2023/10/15 13:49:44.439577, 0] ../../source3/nmbd/nmbd.c:59(terminate) Oct 15 13:49:44 Tower nmbd[8994]: Got SIGTERM: going down... Oct 15 13:49:44 Tower winbindd[9000]: [2023/10/15 13:49:44.439631, 0] ../../source3/winbindd/winbindd_dual.c:1957(winbindd_sig_term_handler) Oct 15 13:49:44 Tower winbindd[9000]: Got sig[15] terminate (is_parent=0) Oct 15 13:49:44 Tower winbindd[8997]: [2023/10/15 13:49:44.439638, 0] ../../source3/winbindd/winbindd_dual.c:1957(winbindd_sig_term_handler) Oct 15 13:49:44 Tower winbindd[8997]: Got sig[15] terminate (is_parent=1) Oct 15 13:49:44 Tower root: cp: cannot create regular file '/boot/config': Input/output error Oct 15 13:49:45 Tower avahi-daemon[9014]: Service "Tower" (/services/ssh.service) successfully established. Oct 15 13:49:45 Tower avahi-daemon[9014]: Service "Tower" (/services/smb.service) successfully established. Oct 15 13:49:45 Tower avahi-daemon[9014]: Service "Tower" (/services/sftp-ssh.service) successfully established. Oct 15 13:49:46 Tower root: Starting Samba: /usr/sbin/smbd -D Oct 15 13:49:46 Tower smbd[9085]: [2023/10/15 13:49:46.473942, 0] ../../source3/smbd/server.c:1741(main) Oct 15 13:49:46 Tower smbd[9085]: smbd version 4.17.3 started. Oct 15 13:49:46 Tower smbd[9085]: Copyright Andrew Tridgell and the Samba Team 1992-2022 Oct 15 13:49:46 Tower root: /usr/sbin/nmbd -D Oct 15 13:49:46 Tower nmbd[9087]: [2023/10/15 13:49:46.494793, 0] ../../source3/nmbd/nmbd.c:901(main) Oct 15 13:49:46 Tower nmbd[9087]: nmbd version 4.17.3 started. Oct 15 13:49:46 Tower nmbd[9087]: Copyright Andrew Tridgell and the Samba Team 1992-2022 Oct 15 13:49:46 Tower root: /usr/sbin/winbindd -D Oct 15 13:49:46 Tower winbindd[9092]: [2023/10/15 13:49:46.516390, 0] ../../source3/winbindd/winbindd.c:1440(main) Oct 15 13:49:46 Tower winbindd[9092]: winbindd version 4.17.3 started. Oct 15 13:49:46 Tower winbindd[9092]: Copyright Andrew Tridgell and the Samba Team 1992-2022 Oct 15 13:49:46 Tower winbindd[9094]: [2023/10/15 13:49:46.521306, 0] ../../source3/winbindd/winbindd_cache.c:3116(initialize_winbindd_cache) Oct 15 13:49:46 Tower winbindd[9094]: initialize_winbindd_cache: clearing cache and re-creating with version number 2 Oct 15 13:49:46 Tower emhttpd: shcmd (121452): /etc/rc.d/rc.avahidaemon restart Oct 15 13:49:46 Tower root: Stopping Avahi mDNS/DNS-SD Daemon: stopped Oct 15 13:49:46 Tower avahi-daemon[9014]: Got SIGTERM, quitting. Oct 15 13:49:46 Tower avahi-dnsconfd[9023]: read(): EOF Oct 15 13:49:46 Tower avahi-daemon[9014]: Leaving mDNS multicast group on interface virbr0.IPv4 with address 192.168.122.1. Oct 15 13:49:46 Tower avahi-daemon[9014]: Leaving mDNS multicast group on interface docker0.IPv4 with address 172.17.0.1. Oct 15 13:49:46 Tower avahi-daemon[9014]: Leaving mDNS multicast group on interface br0.IPv4 with address 192.168.0.195. Oct 15 13:49:46 Tower avahi-daemon[9014]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1. Oct 15 13:49:46 Tower avahi-daemon[9014]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1. Oct 15 13:49:46 Tower avahi-daemon[9014]: avahi-daemon 0.8 exiting. Oct 15 13:49:46 Tower root: Starting Avahi mDNS/DNS-SD Daemon: /usr/sbin/avahi-daemon -D Oct 15 13:49:46 Tower avahi-daemon[9111]: Found user 'avahi' (UID 61) and group 'avahi' (GID 214). Oct 15 13:49:46 Tower avahi-daemon[9111]: Successfully dropped root privileges. Oct 15 13:49:46 Tower avahi-daemon[9111]: avahi-daemon 0.8 starting up. Oct 15 13:49:46 Tower avahi-daemon[9111]: Successfully called chroot(). Oct 15 13:49:46 Tower avahi-daemon[9111]: Successfully dropped remaining capabilities. Oct 15 13:49:46 Tower avahi-daemon[9111]: Loading service file /services/sftp-ssh.service. Oct 15 13:49:46 Tower avahi-daemon[9111]: Loading service file /services/smb.service. Oct 15 13:49:46 Tower avahi-daemon[9111]: Loading service file /services/ssh.service. Oct 15 13:49:46 Tower avahi-daemon[9111]: Joining mDNS multicast group on interface virbr0.IPv4 with address 192.168.122.1. Oct 15 13:49:46 Tower avahi-daemon[9111]: New relevant interface virbr0.IPv4 for mDNS. Oct 15 13:49:46 Tower avahi-daemon[9111]: Joining mDNS multicast group on interface docker0.IPv4 with address 172.17.0.1. Oct 15 13:49:46 Tower avahi-daemon[9111]: New relevant interface docker0.IPv4 for mDNS. Oct 15 13:49:46 Tower avahi-daemon[9111]: Joining mDNS multicast group on interface br0.IPv4 with address 192.168.0.195. Oct 15 13:49:46 Tower avahi-daemon[9111]: New relevant interface br0.IPv4 for mDNS. Oct 15 13:49:46 Tower avahi-daemon[9111]: Joining mDNS multicast group on interface lo.IPv6 with address ::1. Oct 15 13:49:46 Tower avahi-daemon[9111]: New relevant interface lo.IPv6 for mDNS. Oct 15 13:49:46 Tower avahi-daemon[9111]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1. Oct 15 13:49:46 Tower avahi-daemon[9111]: New relevant interface lo.IPv4 for mDNS. Oct 15 13:49:46 Tower avahi-daemon[9111]: Network interface enumeration completed. Oct 15 13:49:46 Tower avahi-daemon[9111]: Registering new address record for 192.168.122.1 on virbr0.IPv4. Oct 15 13:49:46 Tower avahi-daemon[9111]: Registering new address record for 172.17.0.1 on docker0.IPv4. Oct 15 13:49:46 Tower avahi-daemon[9111]: Registering new address record for 192.168.0.195 on br0.IPv4. Oct 15 13:49:46 Tower avahi-daemon[9111]: Registering new address record for ::1 on lo.*. Oct 15 13:49:46 Tower avahi-daemon[9111]: Registering new address record for 127.0.0.1 on lo.IPv4. Oct 15 13:49:46 Tower emhttpd: shcmd (121453): /etc/rc.d/rc.avahidnsconfd restart Oct 15 13:49:46 Tower root: Stopping Avahi mDNS/DNS-SD DNS Server Configuration Daemon: stopped Oct 15 13:49:46 Tower root: Starting Avahi mDNS/DNS-SD DNS Server Configuration Daemon: /usr/sbin/avahi-dnsconfd -D Oct 15 13:49:46 Tower avahi-dnsconfd[9120]: Successfully connected to Avahi daemon. Oct 15 13:49:47 Tower unassigned.devices: Disk with ID 'Kingston_DataTraveler_3.0_E0D55EA57405E371B9C10019-0:0 (sdf)' is not set to auto mount. Oct 15 13:49:47 Tower avahi-daemon[9111]: Server startup complete. Host name is Tower.local. Local service cookie is 616846511. Oct 15 13:49:47 Tower emhttpd: error: get_key_info, 537: No such file or directory (2): opendir: /boot/config Oct 15 13:49:47 Tower emhttpd: Unregistered - missing key file (ENOKEYFILE2) Oct 15 13:49:47 Tower emhttpd: error: put_config_idx, 610: No such file or directory (2): fopen: /boot/config/shares/appdata.cfg Oct 15 13:49:47 Tower emhttpd: error: put_config_idx, 610: No such file or directory (2): fopen: /boot/config/shares/data.cfg Oct 15 13:49:47 Tower emhttpd: error: put_config_idx, 610: No such file or directory (2): fopen: /boot/config/shares/domains.cfg Oct 15 13:49:47 Tower emhttpd: error: put_config_idx, 610: No such file or directory (2): fopen: /boot/config/shares/go.cfg Oct 15 13:49:47 Tower emhttpd: error: put_config_idx, 610: No such file or directory (2): fopen: /boot/config/shares/isos.cfg Oct 15 13:49:47 Tower emhttpd: error: put_config_idx, 610: No such file or directory (2): fopen: /boot/config/shares/system.cfg Oct 15 13:49:47 Tower emhttpd: Starting services... Oct 15 13:49:47 Tower emhttpd: shcmd (121459): /etc/rc.d/rc.samba restart Oct 15 13:49:47 Tower nmbd[9091]: [2023/10/15 13:49:47.781970, 0] ../../source3/nmbd/nmbd.c:59(terminate) Oct 15 13:49:47 Tower nmbd[9091]: Got SIGTERM: going down... Oct 15 13:49:47 Tower winbindd[9097]: [2023/10/15 13:49:47.782008, 0] ../../source3/winbindd/winbindd_dual.c:1957(winbindd_sig_term_handler) Oct 15 13:49:47 Tower winbindd[9097]: Got sig[15] terminate (is_parent=0) Oct 15 13:49:47 Tower winbindd[9094]: [2023/10/15 13:49:47.782019, 0] ../../source3/winbindd/winbindd_dual.c:1957(winbindd_sig_term_handler) Oct 15 13:49:47 Tower winbindd[9094]: Got sig[15] terminate (is_parent=1) Oct 15 13:49:47 Tower root: cp: cannot create regular file '/boot/config': Input/output error Oct 15 13:49:48 Tower avahi-daemon[9111]: Service "Tower" (/services/ssh.service) successfully established. Oct 15 13:49:48 Tower avahi-daemon[9111]: Service "Tower" (/services/smb.service) successfully established. Oct 15 13:49:48 Tower avahi-daemon[9111]: Service "Tower" (/services/sftp-ssh.service) successfully established. Oct 15 13:49:49 Tower root: Starting Samba: /usr/sbin/smbd -D Oct 15 13:49:49 Tower smbd[9174]: [2023/10/15 13:49:49.810503, 0] ../../source3/smbd/server.c:1741(main) Oct 15 13:49:49 Tower smbd[9174]: smbd version 4.17.3 started. Oct 15 13:49:49 Tower smbd[9174]: Copyright Andrew Tridgell and the Samba Team 1992-2022 Oct 15 13:49:49 Tower root: /usr/sbin/nmbd -D Oct 15 13:49:49 Tower nmbd[9176]: [2023/10/15 13:49:49.826571, 0] ../../source3/nmbd/nmbd.c:901(main) Oct 15 13:49:49 Tower nmbd[9176]: nmbd version 4.17.3 started. Oct 15 13:49:49 Tower nmbd[9176]: Copyright Andrew Tridgell and the Samba Team 1992-2022 Oct 15 13:49:49 Tower root: /usr/sbin/winbindd -D Oct 15 13:49:49 Tower winbindd[9181]: [2023/10/15 13:49:49.845920, 0] ../../source3/winbindd/winbindd.c:1440(main) Oct 15 13:49:49 Tower winbindd[9181]: winbindd version 4.17.3 started. Oct 15 13:49:49 Tower winbindd[9181]: Copyright Andrew Tridgell and the Samba Team 1992-2022 Oct 15 13:49:49 Tower winbindd[9183]: [2023/10/15 13:49:49.850526, 0] ../../source3/winbindd/winbindd_cache.c:3116(initialize_winbindd_cache) Oct 15 13:49:49 Tower winbindd[9183]: initialize_winbindd_cache: clearing cache and re-creating with version number 2
October 20, 20233 yr 9 minutes ago, numa said: I ran tools > diagnostics but I certainly can't decipher all that info. I'm posting some of syslog.1.txt here. Attach the zip file to your next post in this thread.
October 20, 20233 yr Author Solution Here is the diagnostics zip --- Problem Fixed --- I'm not sure the issue, but turning things off and on again seemed to work. Edited October 21, 20233 yr by numa
October 20, 20233 yr Try using a different USB port, ideally USB 2.0, if it happens again replace the flash drive.
