November 29, 20232 yr Normally when i rebuild a drive it runs a bit slower until i get past the old 8gb seagate st8000dm004 drives which seem to limit me. then the last 6tb would be fairly fast. My old parity drives were 2 14TB Seagate (ST14000nm001g) which i believe were much faster.. Could this be my new WD parity drive doing the slowdown or is it a product of rebuilding 1 of 2 parity drives? If so i think i should order some faster seagate drives for parity? Edited November 30, 20232 yr by FrozenGamer solved
November 30, 20232 yr Community Expert Solution Unless you have a very old CPU then doing 2 parity drives at the same time can run at a similar speed to doing a single one. If the new parity drive is slower, that WILL slow things down as the speed is determined by the slowest drive at any point in the check. I wonder if the new WD parity drive is using SMR technology rather than CMR as that could make a big difference .
November 30, 20232 yr Author I don't know if it is CMR or not, i will see if i can find that out .. i hope not!
November 30, 20232 yr Community Expert 1 minute ago, FrozenGamer said: I don't know if it is CMR or not, i will see if i can find that out .. i hope not! CMR is fine - it is SMR that can be very slow once the drives internal buffer gets full.
November 30, 20232 yr Author It is now just finishing the rebuild.. at 106 MB/S and started and stayed at about 57 MB/s.. Total time will have been 3 days 1.4 hrs, but i have 29 drives and really need to find a different caddy to store the drives with faster throughput i think.. eliminating the slower 8tb seagate smr drives will help. (3 more to get rid of) but those i think were just slow on the write and not so much on the read.. 3 days isn't a terrible overall time compared to my normal times though on the with 14tb seagate faster drives for parity, considering i am doing 4 more TB.
November 30, 20232 yr Community Expert 8 minutes ago, FrozenGamer said: eliminating the slower 8tb seagate smr drives will help. (3 more to get rid of) but those i think were just slow on the write and not so much on the read. Yes, SMR drives can slow down when writing but should read at normal speeds. When there was a considerable price advantage to using SMR drive then it made sense with Unraid as it is most frequently used with media data that stays static once written so the write penalty was bearable.
November 30, 20232 yr Author According to this site i have CMR.. happy since i bought 5 for 199 each at bestbuy.. thanks for your help! https://nascompares.com/answer/list-of-wd-cmr-and-smr-hard-drives-hdd/
