October 7, 201114 yr I just found that the read speed of my unRAID dropped to zero for a very short period (less that a second) every 1 - 2 mins. The result was that the playback of video freeze for a very short period every 1 - 2 mins. Any hints for me to debug? ---- One founding was that even without any read/write access to my unRAID, the disk access light for all drive that spin-up will be on in sequence every 1 - 2 mins. Is there any process /plugin will access the harddisk in sequence every 1 - 2 mins? ---- In addition, I got 2 GB Ram in unRAID, is it possible to use some memory as buffers, so that even my harddisk was busy every 1-2 mins by other process, I can still got some steady output. ---- My Setup Motherboard - Gigabyte X48-DQ6 CPU - Intel C2D E8400 RAM - 2GB DDR2-800 Parity Disk - Hitachi 7K3000 7200rpm 2TB (on Channel 0 of 1st Sil3132 PCI-e 1x card) Disk 1 to 8 - Hitachi 5K3000 5900rpm 2TB x 8 (on board ICH9 (AHCI) x 6 + on board JMicorn (AHCI) x 2) Cache Disk - WD 7200rpm 1TB (on Channel 0 of 2nd Sil3132 PCI-e 1x card) UnRaid 4.7 AIO
October 7, 201114 yr Linux uses all available memory for disk buffering. If a process needs more memory then memory is taken from the disk buffers.
October 7, 201114 yr Author Thanks a lot! Any hints for me to solve the problem I found? Attached please find the syslog syslog.txt
October 7, 201114 yr What are your system specs? Are you running any add-ons? Show the output of "top".
October 8, 201114 yr Author My Setup Motherboard - Gigabyte X48-DQ6 CPU - Intel C2D E8400 RAM - 2GB DDR2-800 Parity Disk - Hitachi 7K3000 7200rpm 2TB (on Channel 0 of 1st Sil3132 PCI-e 1x card) Disk 1 to 8 - Hitachi 5K3000 5900rpm 2TB x 8 (on board ICH9 (AHCI) x 6 + on board JMicorn (AHCI) x 2) Cache Disk - WD 7200rpm 1TB (on Channel 0 of 2nd Sil3132 PCI-e 1x card) UnRaid 4.7 AIO ----- TOP result (when I copy file from unRAID) top - 09:20:43 up 7:44, 1 user, load average: 1.73, 1.82, 1.85 Tasks: 98 total, 2 running, 96 sleeping, 0 stopped, 0 zombie Cpu(s): 0.8%us, 7.0%sy, 0.0%ni, 34.4%id, 50.0%wa, 5.0%hi, 2.8%si, 0.0%st Mem: 2073808k total, 2025872k used, 47936k free, 346052k buffers Swap: 0k total, 0k used, 0k free, 1478524k cached PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 4439 root 20 0 15808 5256 3772 R 8 0.3 7:20.97 smbd 2624 root 20 0 81344 11m 708 S 6 0.6 11:54.21 shfs 2134 root 20 0 0 0 0 S 2 0.0 2:34.03 unraidd 322 root 20 0 0 0 0 S 1 0.0 1:06.00 kswapd0 1 root 20 0 700 328 288 S 0 0.0 0:01.61 init 2 root 20 0 0 0 0 S 0 0.0 0:00.00 kthreadd 3 root RT 0 0 0 0 S 0 0.0 0:00.07 migration/0 4 root 20 0 0 0 0 S 0 0.0 0:00.00 ksoftirqd/0 5 root RT 0 0 0 0 S 0 0.0 0:00.04 migration/1 6 root 20 0 0 0 0 S 0 0.0 0:00.00 ksoftirqd/1 7 root 20 0 0 0 0 S 0 0.0 0:00.00 events/0 8 root 20 0 0 0 0 S 0 0.0 0:00.00 events/1 9 root 20 0 0 0 0 S 0 0.0 0:00.00 khelper 14 root 20 0 0 0 0 S 0 0.0 0:00.00 async/mgr 116 root 20 0 0 0 0 S 0 0.0 0:10.33 sync_supers 118 root 20 0 0 0 0 S 0 0.0 0:00.00 bdi-default 120 root 20 0 0 0 0 S 0 0.0 0:00.00 kblockd/0 ---- TOP result (after the copy was completed) top - 09:25:38 up 7:49, 1 user, load average: 1.35, 1.52, 1.71 Tasks: 98 total, 1 running, 97 sleeping, 0 stopped, 0 zombie Cpu(s): 0.0%us, 0.0%sy, 0.0%ni, 50.0%id, 50.0%wa, 0.0%hi, 0.0%si, 0.0%st Mem: 2073808k total, 1524112k used, 549696k free, 414604k buffers Swap: 0k total, 0k used, 0k free, 903780k cached PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 1 root 20 0 700 328 288 S 0 0.0 0:01.61 init 2 root 20 0 0 0 0 S 0 0.0 0:00.00 kthreadd 3 root RT 0 0 0 0 S 0 0.0 0:00.07 migration/0 4 root 20 0 0 0 0 S 0 0.0 0:00.00 ksoftirqd/0 5 root RT 0 0 0 0 S 0 0.0 0:00.04 migration/1 6 root 20 0 0 0 0 S 0 0.0 0:00.00 ksoftirqd/1 7 root 20 0 0 0 0 S 0 0.0 0:00.00 events/0 8 root 20 0 0 0 0 S 0 0.0 0:00.00 events/1 9 root 20 0 0 0 0 S 0 0.0 0:00.00 khelper 14 root 20 0 0 0 0 S 0 0.0 0:00.00 async/mgr 116 root 20 0 0 0 0 S 0 0.0 0:10.33 sync_supers 118 root 20 0 0 0 0 S 0 0.0 0:00.00 bdi-default 120 root 20 0 0 0 0 S 0 0.0 0:00.00 kblockd/0 121 root 20 0 0 0 0 S 0 0.0 0:00.00 kblockd/1 122 root 20 0 0 0 0 S 0 0.0 0:00.00 kacpid 123 root 20 0 0 0 0 S 0 0.0 0:00.00 kacpi_notify 124 root 20 0 0 0 0 S 0 0.0 0:00.00 kacpi_hotplug
October 8, 201114 yr Author As I remember, Just a few for management only, no other plugin that related to video-transcode that need a lot of CPU was installed. 1) unMenu 2) socat 3) unraid_notify 4) powerdown 5) apcupsd 6) over-temp shutdown 7) cache_dirs ----- I attache the GO script for your information #!/bin/bash # Start the Management Utility /usr/local/sbin/emhttp & installpkg /boot/package/socat-1.7.0.0-i486-2bj.tgz installpkg /boot/package/unraid_notify-2.55-noarch-unRAID.tgz unraid_notify start cd /boot/packages && find . -name '*.auto_install' -type f -print | sort | xargs -n1 sh -c /boot/unmenu/uu sysctl -w kernel.poweroff_cmd="/sbin/powerdown" /boot/cache_dirs -B -w
October 8, 201114 yr Author I never use XMBC, I just use a stand-alone network player to playback the video file in my NAS through gigalan.
October 8, 201114 yr Author Thanks a lot for your advice. I tried disable cache_dirs by running "cache_dirs -q" in console to kill the job but it just the same.
October 8, 201114 yr Thanks a lot for your advice. I tried disable cache_dirs by running "cache_dirs -q" in console to kill the job but it just the same. OK. It looks like this is a real "who-done-it", and we've just ruled out the handyman. Now, let's try to rule out an "inside job", in general. Disconnect the unRAID server's ethernet connection. Is the culrpit still active? I'm suspecting not (but this is how us "detectives" do our job ). [re-establish the enet connection] If it is an "outside job", let's see what part of town he's from. Individually (one by one), disconnect each client from your network and test for suspicious activity. Report back, and we'll seek an indictment. If, however, it is an inside job, we can call in CSI. [While doing your sleuthing, try to get an exact timing of this activity--both the interval from one start to the next start, and the duration, in seconds (that "one or two minutes" won't hold up in court).] -- UhClem "Nick Danger, third eye"
October 8, 201114 yr Author Thanks a lot for your advice. Actually I tried disconnect the network connection and the situation remain unchanged. Without any lines related to this activity in the syslog, it is not easy to count the number of sec between each incident. -------------------- Anyway I solved the problem by upgrading the system from 4.7 to 5.0b6. After the upgrade, the problem disappear.
