January 2, 20242 yr Hi, so im corrently running my old amd desktop downgraded to Athlon II X2 260u with 4x1 GB of ram and i still have power hungry amd build from 2006 that in idle consume about 73w with all drives power down. I know, i know pc is old and i need to replace it with newer stuff, since when running 24/7 power consumption is importent. So i started to look for some used pc parts and i found 3 already made bundle one is: 88,00 EUR - ASUS Q170M-C + i3 6100 + 8GB DDR4 another: 90,00 EUR - Fujitsu D3441 + i3 6100 + 8GB DDR4 And last that is most expensive (but newer): 120,00 EUR - ASUS PRIME B360M-C + Pentium G5400 + 8GB DDR4 Can you recomend what to do, 6100 i can get with 6100T cpu also for same price,
January 3, 20242 yr 22 hours ago, Doktor-X said: Can you recomend what to do, 6100 i can get with 6100T cpu also for same price, The newer set is probably worth the slight premium. The 6100T is a slower, underclocked version of the 6100 - it won't save you electricity.
January 4, 20242 yr 11 hours ago, Lolight said: The newer set is probably worth the slight premium. The 6100T is a slower, underclocked version of the 6100 - it won't save you electricity. yea, T model isn't worth the money if you need to buy one with same price, if you got it cheaper or from dumpster diving it's ok.
