March 17, 20242 yr Hi there, I use the Backup Script by mgutt for all my backups. Now its a little bit anoying to visit every backup folder to check the log file. I want to save all the log files to one share, where i can access them directly. I am not that good at bash scripting so can anybody help me please? I found this in the end of the script and i tried many things to move the file to a share. But it did not work. # move log file to destination log_path=$(rsync --dry-run --itemize-changes --include=".$new_backup/" --include="$new_backup/" --exclude="*" --recursive "$dst_path/" "$empty_dir" | cut -d " " -f 2) [[ $log_path ]] && rsync "${dryrun[@]}" --remove-source-files "$log_file" "$dst_path/$log_path/$new_backup.log" [[ -f "$log_file" ]] && rm "$log_file" done I asked in the Rsync Incremental Thread but no response. I wrote a PN to mgutt but he did not answer to this time. So i try it here again. Thank you for your help!
April 2, 20242 yr Hi Naitor If you still need help? I have a lot of fun to write scripts and therefore offer my help.. However, I would need a larger section like this. But there are some errors here.. ^^ Maybe this will help you orientate yourself: # Sample variables (ensure these variables are correctly) dst_path="/path/to/destination" # Destination directory log_file="/path/to/logfile.log" # Path to the log file new_backup="backup-$(date +%Y-%m-%d)" # New backup folder, e.g., backup-2023-04-01 # Create the new backup directory in the destination directory if it does not exist mkdir -p "$dst_path/$new_backup" # Check if the log file exists, and then move it using rsync if [[ -f "$log_file" ]]; then # Use rsync to move the log file to the new backup directory and then delete the original rsync -av --remove-source-files "$log_file" "$dst_path/$new_backup/" # Check if rsync worked correctly if [ $? -eq 0 ]; then echo "Log file has been moved to: $dst_path/$new_backup/$(basename "$log_file")" else echo "Failed to move the log file." fi else echo "Log file does not exist: $log_file" fi
