Issue regarding Mellanox MCX311A-XCAT ConnectX-3 EN 10G Ethernet 10GbE SFP+ PCIe NIC and how I solved it
So back story, I ordered a "Mellanox MCX311A-XCAT ConnectX-3 EN 10G Ethernet 10GbE SFP+ PCIe NIC w/2 Bracket" from eBay. Everything seemed fine and was working as I assumed as expected. I noticed the next day in the logs the Mellanox nic was up and down like a yo-yo causing a bunch of issues on my network. At first I assumed I had a bad cable, or bad NIC card. (or even a bad port on my new USW-Pro-Max-24-PoE)
I solved the issue by installing the Mellanox Firmware Tools plugin and updated to the newest version.
# mstflint -d 04:00.0 -i *.bin burn
    Current FW version on flash:  2.33.5220
    New FW version:               2.42.5000
Burn process will not be failsafe. No checks will be performed.
ALL flash, including the Invariant Sector will be overwritten.
If this process fails, computer may remain in an inoperable state.
 Do you want to continue ? (y/n) [n] : y
Burning FS2 FW image without signatures - OK
Restoring signature                     - OK
Once this was flashed to the latest version, all my issues went away.
I just wanted to drop this here, incase anyone else comes across the same issue.
Edited by spyd4r
wow thanks, same card same issue
  • spyd4r changed the title to Issue regarding Mellanox MCX311A-XCAT ConnectX-3 EN 10G Ethernet 10GbE SFP+ PCIe NIC and how I solved it
thanks OP
last few days I have been noticing a lot of ntw drops out of the blue. Haven't found a solution yet
example
Jun 27 14:52:35 server kernel: mlx4_en: eth0: Link Down
Jun 27 14:52:35 server kernel: br0: port 1(eth0) entered disabled state
Jun 27 14:52:38 server kernel: mlx4_en: eth0: Link Up
Jun 27 14:52:38 server kernel: br0: port 1(eth0) entered blocking state
Jun 27 14:52:38 server kernel: br0: port 1(eth0) entered forwarding state
Jun 27 14:56:54 server kernel: mlx4_en: eth0: Link Down
Jun 27 14:56:54 server kernel: br0: port 1(eth0) entered disabled state
Jun 27 14:56:57 server kernel: mlx4_en: eth0: Link Up
Jun 27 14:56:57 server kernel: br0: port 1(eth0) entered blocking state
Jun 27 14:56:57 server kernel: br0: port 1(eth0) entered forwarding state
Jun 27 14:58:23 server kernel: mlx4_en: eth0: Link Down
Jun 27 14:58:23 server kernel: br0: port 1(eth0) entered disabled state
Jun 27 14:58:27 server kernel: mlx4_en: eth0: Link Up
Jun 27 14:58:27 server kernel: br0: port 1(eth0) entered blocking state
Jun 27 14:58:27 server kernel: br0: port 1(eth0) entered forwarding state
  • 2 years later...
Hi @spyd4r ! Got it solved? I'm about to buy that card too. Maybe a power issue?
