Out of Memory errors from fix common problems
Out of Memory Error popped up last night, never seen one before. Haven't noticed any degradation or killed processes.
Uptime of 45 days... time for a reboot?
stratus-diagnostics-20240526-0713.zip
22 minutes ago, birdsofprey02 said:
time for a reboot?
Probably a good idea, python3 was the process killed, created by a container, dotnet was also using a lot of RAM, possibly from the same container.
Have you also checked the Minimum Free Space setting I mentioned for the 'media' pool?   If set correctly that would have protected you if mover was not putting files onto the array fast enough by stopping the pool getting completely full.
