jargo Posted August 14 Share Posted August 14 (edited) My VM disk has no space remaining, and the space is not recovered after moving a VM image off of the disk, or by defrag/optimization of the windows drives after adding discard='unmap' to the VM XML I am using ZFS and qcow2 if those could have something to do with it. Any help would be appreciated. Edited August 14 by jargo problem update Quote Link to comment
Solution JorgeB Posted August 14 Solution Share Posted August 14 8 hours ago, jargo said: My VM disk has no space remaining, and the space is not recovered after moving a VM image off of the disk, or by defrag/optimization of the windows drives after adding discard='unmap' to the VM XML That suggest it's really full, and you need to delete some data or expand it. Quote Link to comment
jargo Posted August 14 Author Share Posted August 14 1 hour ago, JorgeB said: That suggest it's really full, and you need to delete some data or expand it. Thank you. My mistake was that I had a bunch of snapshots, which naturally include a lot of old data. I had erroneously thought that the snapshots were being saved on my backup drive on the array, but they are on the cache-vm disk as well and are simply being replicated. Doh! 1 Quote Link to comment
