November 21, 20241 yr Submitting a ticket as described from Fix Common Problems when MCE's are found in the log. tower-diagnostics-20241120-1657.zip
November 21, 20241 yr Community Expert reboot unraid and run mem test 90% its ecc mermoy corecting itself
November 21, 20241 yr Author 20 minutes ago, bmartino1 said: reboot unraid and run mem test 90% its ecc mermoy corecting itself did that and memtest came back with out any issues; i will double check but fairly sure its non-ecc memory; should I run it again?
November 21, 20241 yr Community Expert no if mem test is clear it could be something else. Another user may need to assit your further form here. mermory - hardware errors are fickle. could be a variety of things. Cstates in bios, xmp prfioles, overclocking. sometimes even bent or hurt processor pins . hard to say. thanks for post diag i think @Jorgeb may be better able to assit here.
