Power-on or device reset occurred - Power issue vs pre-failure?
Hello Friends!
One of my drives errored out today and, looking at the logs, it appears that it was around a power-retract event. Short SMART test passed and no SMART errors on the dashboard but some suspect things in the drive SMART logs (attached). Looking for advice on where to start - checking cables, change out PSU vs drive, or is there something I'm missing?
Dec 11 09:19:37 Neo root: Fix Common Problems: Error: disk7 (WDC_WD120EMFZ-11A6JA0_X1G4PTEL) is disabled
Dec 11 09:19:37 Neo root: Fix Common Problems: Error: disk7 (WDC_WD120EMFZ-11A6JA0_X1G4PTEL) has read errors
Looking back at the logs:
Dec 10 19:50:59 Neo emhttpd: read SMART /dev/sdd
Dec 10 19:50:59 Neo emhttpd: read SMART /dev/sdc
Dec 10 19:51:43 Neo kernel: sd 7:0:0:0: Power-on or device reset occurred
Dec 10 20:07:15 Neo emhttpd: spinning down /dev/sdd
Dec 10 20:07:15 Neo emhttpd: spinning down /dev/sdc
Dec 10 20:51:10 Neo kernel: sd 7:0:0:0: Power-on or device reset occurred
Dec 10 20:51:10 Neo emhttpd: read SMART /dev/sdd
Dec 10 20:51:10 Neo emhttpd: read SMART /dev/sdc
Dec 10 21:07:40 Neo emhttpd: spinning down /dev/sdd
Dec 10 21:07:40 Neo emhttpd: spinning down /dev/sdc
Dec 10 21:51:21 Neo emhttpd: read SMART /dev/sdd
Dec 10 21:51:21 Neo emhttpd: read SMART /dev/sdc
Dec 10 21:52:02 Neo kernel: sd 7:0:0:0: [sdd] tag#458 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=DRIVER_OK cmd_age=0s
Dec 10 21:52:02 Neo kernel: sd 7:0:0:0: [sdd] tag#458 Sense Key : 0x2 [current]
Dec 10 21:52:02 Neo kernel: sd 7:0:0:0: [sdd] tag#458 ASC=0x4 ASCQ=0x0
Dec 10 21:52:02 Neo kernel: sd 7:0:0:0: [sdd] tag#458 CDB: opcode=0x35 35 00 00 00 00 00 00 00 00 00
Dec 10 21:52:02 Neo kernel: I/O error, dev sdd, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 2
Dec 10 21:52:02 Neo kernel: sd 7:0:0:0: [sdd] tag#459 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=DRIVER_OK cmd_age=0s
Dec 10 21:52:02 Neo kernel: sd 7:0:0:0: [sdd] tag#459 Sense Key : 0x2 [current]
Dec 10 21:52:02 Neo kernel: sd 7:0:0:0: [sdd] tag#459 ASC=0x4 ASCQ=0x0
Dec 10 21:52:02 Neo kernel: sd 7:0:0:0: [sdd] tag#459 CDB: opcode=0x8a 8a 08 00 00 00 02 80 03 1a 88 00 00 00 08 00 00
Dec 10 21:52:02 Neo kernel: I/O error, dev sdd, sector 10737621640 op 0x1:(WRITE) flags 0x20800 phys_seg 1 prio class 2
Dec 10 21:52:02 Neo kernel: md: disk7 write error, sector=10737621576
Dec 10 21:52:02 Neo kernel: sd 7:0:0:0: [sdd] tag#460 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=DRIVER_OK cmd_age=0s
Dec 10 21:52:02 Neo kernel: sd 7:0:0:0: [sdd] tag#460 Sense Key : 0x2 [current]
Dec 10 21:52:02 Neo kernel: sd 7:0:0:0: [sdd] tag#460 ASC=0x4 ASCQ=0x0
Dec 10 21:52:02 Neo kernel: sd 7:0:0:0: [sdd] tag#460 CDB: opcode=0x88 88 00 00 00 00 02 80 03 1a 90 00 00 00 08 00 00
Dec 10 21:52:02 Neo kernel: I/O error, dev sdd, sector 10737621648 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
Dec 10 21:52:02 Neo kernel: md: disk7 read error, sector=10737621584
Dec 10 21:52:02 Neo emhttpd: read SMART /dev/sdj
Dec 10 21:52:02 Neo emhttpd: read SMART /dev/sdk
Dec 10 21:52:02 Neo emhttpd: read SMART /dev/sdh
Dec 10 21:52:02 Neo emhttpd: read SMART /dev/sdg
Dec 10 21:52:02 Neo emhttpd: read SMART /dev/sde
Dec 10 21:52:02 Neo emhttpd: read SMART /dev/sdf
Dec 10 21:52:02 Neo emhttpd: read SMART /dev/sdi
Dec 10 21:52:12 Neo kernel: sd 7:0:0:0: Power-on or device reset occurred
Dec 10 21:54:11 Neo kernel: mdcmd (50): set md_write_method 1
In the drive SMART logs (attached), here are the things that stand out to me:
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x028  4              10  ---  Read Recovery Attempts
0x03  0x030  4               1  ---  Number of Mechanical Start Failures
The only only drive that has a non-zero Number of Mechanical Start Failures (also 1) is of the exact same model (and have been in another server before, so not certain how new it is).
Thanks in advance!
WDC_WD120EMFZ-11A6JA0_X1G4PTEL-2024-07-16 disk7 (sdd) - DISK_DSBL.txt
Edited by sreknob
Solved by Michael_P
40 minutes ago, sreknob said:
checking cables
Check the power cables and remove any splitters
Doesn't look like a disk problem, at least not media related, could be a mechanical issue, but first try swapping cables (both power and SATA) with a different disk and see where the problem follows
Thank you two for the replies.
That was my inclination as well, just wanted to see if I was missing anything in the logs.
Will do some re-wiring and rebuild with the same disk for now.
Will update with any additional events.
  • 5 weeks later...
As a follow-up, this one disk eventually completely failed and no longer is recognized on multiple devices, despite spinning up.
Removed splitters and re-did all the cabling.
May have been the power, may have been bad luck.
Thanks again.
