September 9, 20251 yr I replaced a hard drive in a ZFS mirror and the newly replaced drive has a blue square icon next to it saying it's "new". I read somewhere that means the drive it being rebuilt, but there is no I/O on the array and the output of: zpool status <pool> -v shows the drive simply as "online" like the others. Not sure how to clear it to make it green again and it's been several days. Thanks
September 9, 20251 yr Typically you just need to reimport the pool to fix that, but post the diags first as mentioned to confirm the pool is OK.
September 9, 20251 yr Author Attached as requested. I replaced sde, I'm aware of the issue with sdf, it seems to be something different I'm dealing with.backup-diagnostics-20250909-1232.zip Edited September 9, 20251 yr by tdp252
September 10, 20251 yr Reimporting the pool should fix the icon issue:on main click on the first device for that pool and then "remove pool"back on main, create a new pool with the same name and number of slotsassign the pool device(s), any order, leave the filesystem set to autostart the array to import the pool
