November 15, 2025Nov 15 Hi everyone.I recently upgraded my server.I went with an ultra 225, asrock b860m-x, and 32 ddr5 ram.I have 5 x 3.5 hdd (one parity) and 1 ssd. The ssd is attached to this extension has the mb has only 4 sata ports. https://s.click.aliexpress.com/e/_DEJn6pLbeen watching some tutorials there and then and it says you have to change a few things in bios settings. To be honest, it goes a bit beyond my skills and i'm afraid to break something... (https://forums.unraid.net/topic/98070-reduce-power-consumption-with-powertop/#comment-904898) and some wolfgang and spaceinvaderone videos.So far, i managed to :- spin down disks after 15 min unused- disable hd Audio- disable RGB LED controllerWhat i'm probably missing are (from the tuto above):1. should i disable igpu multi monitor ?2. enable ASPM (Active-State Power Management) in the PCI settings ?enable all C-States like C7/C9/C10 in the CPU settings ("auto" usually means "disabled", so select "enable")questions:as i understand i would disable the gpu from the motherboard and only use the cpu gpu ?!? (i am afraid to go into a unrocoverable black screen...)I found severals options under advanced\chipset config: pcie aspm support (disabled, l0s, l1, l0sl1, auto), pch pcie aspm support, pch dmi support, dmi aspm support. there are many options and i have no idea of consequencesunder advanced/cpu it says cpu state support enable. but then it says c state auto domotion c1, undemotion c1, package demotion enabled, package undemotion enabled. should i disabled those to manually change them ?Should i disable turbo boost under oc tweaker ?what about boot performance mode ? max battery ? max non turbo preference ? it's set to turbo performance by default. Is it drawing more power to boot faster ?can i use powertop ? is there a tutorial ? (i mean i noob friendly for my case because apparently it's harder if you use an nvme to sata card.PS: currently while browing bios i'm at 52 wats, in unraid after boot and array on at 45w, and around 28w when all disks are spin down (only plex has container).thanks a lot and take care Edited November 16, 2025Nov 16 by tomume
