jnye6601: problem found by [Plugin] CA Fix Common Problems (not problem with FCP itself)
So I have this share issue with Nextcloud. I ended up with two shares 'Nextcloud' and 'nextcloud'. This was the result of having to reinstall the docker on day one.
I have since renamed 'nextcloud' as 'old.nextcloud' and reset the Nextcloud docker to point to 'Nextcloud'. I'm not sure if parity is at work here or I've missed a setting, but 'nextcloud' is back. Like WTF dude!?
I just want to be sure that I can copy everything over and run into this happening again....so I'm not repeating this process.
Any insights are appreciated
memory-alpha-diagnostics-20261127-1502.zip
I have split your post into its own thread, since it is not about a problem with the FCP plugin itself. As explained in the very first post of the FCP thread:
On 5/8/2016 at 4:01 PM, Squid said:
Any support for problems this plugin finds, should be posted in the General v6 section of these forums.
Most likely the reason for that share returning in a different case is because you still have it mapped in your container that way.
And there is absolutely no way parity is involved at all. Parity doesn't even know anything about files and folders.
Post docker run for NextCloud.
