July 29, 201214 yr running unraid 5b14 recently got ALOT of errors during parity check I believe I shut down, reset power and sata cables. Started back and 2 drives red balled. One unformatted and one showing up as wrong drive I shut down again swapped out the sata cables, and unplugged the cache drive. Started up again and one disk is still disabled. Ran short and long smartctl test on the drive Can anyone help in interpreting the results. Have read up on it but don't have a background in IT so.... Where to go from here, Trust my array procedure? long smart ctl test results Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x3031) SCT Status supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 1009 3 Spin_Up_Time 0x0027 195 171 021 Pre-fail Always - 5216 4 Start_Stop_Count 0x0032 099 099 000 Old_age Always - 1164 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0 9 Power_On_Hours 0x0032 086 086 000 Old_age Always - 10392 10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 303 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 92 193 Load_Cycle_Count 0x0032 179 179 000 Old_age Always - 64569 194 Temperature_Celsius 0x0022 119 113 000 Old_age Always - 31 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 198 000 Old_age Always - 51 198 Offline_Uncorrectable 0x0030 200 198 000 Old_age Offline - 51 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 198 000 Old_age Offline - 51 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed: read failure 40% 10382 2227052200 # 2 Short offline Completed without error 00% 10378 - # 3 Short offline Completed without error 00% 10378 - # 4 Short offline Completed without error 00% 9384 - # 5 Short offline Completed without error 00% 9384 - # 6 Short offline Completed without error 00% 9176 - # 7 Short offline Completed without error 00% 9175 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. syslog-20120728-112815.txt
July 29, 201214 yr What is the current state of your array, can you still get to your data ? Wrt the smart results: The smart results show that there are definite drive errors, I would get a new drive, preclear it and replace this one, then put this one thru a rigoreous preclear cycle to see if the errors mount up (get more).. The power on hours signify that your drive might still be under guarantee so you can possibly RMA it..
July 29, 201214 yr The value that is of concern is the Current_Pending_Sector. Those sectors caused the read errors. Do you have a pre-cleared spare drive? Otherwise un-assign and pre clear the drive. Then post a new SMART report. If the Current_Pending_Sector goes to zero, you can assign and rebuild the drive.
July 30, 201214 yr Author Thank you very much for your prompt assistance. I don't have a pre-cleared spare laying around. I That would have definitely been optimal. :'( hmm I did start the array briefly with the drive disabled and was able to access the data. Presently I have the server shutdown. just in case. sorry results pasted were not complete was just looking at the results when I had pre-cleared it a month ago and it definitely looks troubling Raw_Read_Error_Rate 514->1009 current pending sectors: from 4->51 Offline_Uncorrectable: 0->51 Multi_Zone_Error_Rate: 0->51 Is this worth further testing or should I just RMA it now. I have until 03/25/2013. thank you again for your assistance smart.txt preclear_finish__WD-WMAVU2279913_2012-06-27.txt preclear_rpt__WD-WMAVU2279913_2012-06-27.txt
July 30, 201214 yr I would not use any drive that has pending sectors. Repeat pre-clear until pending sectors goes to zero or RMA.
July 30, 201214 yr I would not use any drive that has pending sectors. Repeat pre-clear until pending sectors goes to zero or RMA. IF A PRECLEAR DISK PROCESS ENDS WITH SECTORS PENDING REALLOCATION, Repeat pre-clear until pending sectors goes to zero and STAYS AT ZERO FOR AY LEAST ONE ADDITIONAL CYCLE or RMA.
