Question about write speed
I'd say that's not a tiny glitch either... that's a huge speed difference.
Well you were 100 % correct, that was the problem. That pretty much sucks for me, since the unRAID version that I am running on seems to be the only version that will even work with SAS2LP controllers.
Downgrade to RC5 as it uses older kernel and try again - or if you wish you can go to the latest RC6-test2 (you are using RC6-test).
  • 4 months later...
What speeds are you getting with your SAS2LP now?  What version of unRAID are you running now?
