First build, help b/t 2 motherboards
I'm building my first Unraid server.  Budget is under $1,000.  I've settled on the Rosewill RSV-L4000 case, and 3TB WD Red drives for data and parity.  Now I need help with the motherboard/CPU
I want low power.  I will be serving blu ray rips  and music to 3 XBMC clients.  I'd like to run the Usenet trinity, subsonic, and mysql for syncing my XBMC libraries.
What do you think about
1) Asus C60M1-I
2) Biostar NM70I-847
I'd like up to 8 data drives so each one I'd have to add sata cards.  Starting out ill just have one parity and one data.
ASRock Z77 Extreme4 with a low power Celeron G1610
Has 8 sata ports on the motherboard.  Will be a few bucks more but will save you in expansion card.
This is a ATX motherboard but it looks like your case will fit E-ATX and below.
That board is almost $400.  How about a b75 Pro3-M?
I was looking at an Asus... Sorry.  I see its about $125, what about that Asrock for $70
Nothing wrong with the ASUS board but it's not that great if you ever wanted to expand to a larger case for more drives.  Not very upgrade friendly.  It only has 1 PCI-e slot at 4x.  It will work just fine though.
The board i mentioned has 2-PCI3.0 8x slots.  2-IBM m1015 cards at 8x (16 drives) and 8 on board.  Nice system supporting 24 drives.
I don't want to hijack this thread, but, mhaaland, have you used this ASRock Z77 Extreme4 board for an unraid build? It sounds perfect for a 24 disk build I have that may require a new mb. Would love to have confirmation that there are no unexpected problems.
Thanks.
Sorry,  I have not pulled the trigger yet.  Im still researching.  Just going off specs.  I was looking for the cheapest board that had 2 -(PCI-e 8x) and 8 onboard sata connections.  I have a 24-bay supermicro case with an old Xeon processor and Supermicro board.  It pulls 160 watts at idle so i'm in the process of upgrading.
Another option is GIGABYTE GA-Z68XP-UD3.  PCI-e 2.0 16x and 8x with 8 onboard sata.  $90 after rebate at the egg.
