May 17, 201313 yr Hello. I've been having this problem watching videos on XBMC (openelec) that often when I start the video the audio will start for a second with no picture, then the audio cuts out and the screen turns green and just freezes so that there's no way to get out except to hold the power button down and restart. The last time it happened I captured this from the XBMC log: 07:13:36 T:140694580610816 WARNING: CRenderManager::FlipPage - timeout waiting for previous frame 07:13:43 T:140694336567040 WARNING: Previous line repeats 1 times. 07:13:43 T:140694336567040 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available 07:13:48 T:140694580610816 WARNING: CRenderManager::FlipPage - timeout waiting for previous frame 07:13:48 T:140694336567040 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available So it sounds like the network connection between the HTPC and the server must be dropping out, right? If so, how do I go about identifying exactly why this is happening so I can fix it? The server is a new build and my one apprehension about the board I got (ASUS C60M1-I) was the Realtek NIC since I'd read a lot of folks had problems with those in the past (though I also understood that the latest versions of unRAID largely fixed that problem for most people). Is there a particular unRAID log or diagnotic I could use to know whether that's the problem? Appreciate any guidance on this and let me know if there's any other info I can provide.
May 17, 201313 yr Author Forgot to mention I'm running 5.0-rc12a and I've attached my syslog too. There's nothing in it that corresponds to the timing of the of last green screen freeze from the XBMC log posted above but hopefully someone more knowledgeable might be able to glean something from it anyway. syslog_5-17-13.zip
May 17, 201313 yr Author Here's more info on my network configuration. Does seem like a lot of dropped packets, no? root@Server:~# ifconfig -a eth0 Link encap:Ethernet HWaddr 50:46:5d:a5:17:b1 inet addr:192.168.1.147 Bcast:192.168.1.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:1819159117 errors:0 dropped:37407 overruns:0 frame:0 TX packets:1032602677 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:374719276 (357.3 MiB) TX bytes:1781561105 (1.6 GiB) Interrupt:40 Base address:0xe000 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:16749 errors:0 dropped:0 overruns:0 frame:0 TX packets:16749 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:1548511 (1.4 MiB) TX bytes:1548511 (1.4 MiB) root@Server:~# ethtool -i eth0 driver: r8168 version: 8.035.00-NAPI firmware-version: bus-info: 0000:04:00.0 root@Server:~# ethtool eth0 Settings for eth0: Supported ports: [ TP ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Supports auto-negotiation: Yes Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Advertised pause frame use: Symmetric Receive-only Advertised auto-negotiation: Yes Speed: 1000Mb/s Duplex: Full Port: Twisted Pair PHYAD: 0 Transceiver: internal Auto-negotiation: on MDI-X: Unknown Supports Wake-on: pumbg Wake-on: g Current message level: 0x00000033 (51) Link detected: yes
May 18, 201313 yr Here's more info on my network configuration. Does seem like a lot of dropped packets, no? Read this thread.
